where to find a 3400 build guide
  • brianfulcher15
    • Jun 2007
    • 2
    hi ive been trying to find a build guide for a 3400 motor could someone point me in the right direction. im planing on building a 3400 and turboing it seeking 325 to 350ish. its going in my 92 jbody. im really looking for part numbers also thanks
    brian
  • PCGUY112887
    • Feb 2006
    • 1067
    Part numbers for what really?
    If you want to do over about 10psi your going to need pistons, however 10psi should be able to get you into the range you are looking at. You will need injectors, some custom fabbing to get the turbo and such in there... try the Search button on top, there has been TONS of discussion about turbos on the 3x00 engines (3100,3400,3500). You can also get some stuff such as a cam ground for a turbo, ported and polished parts, springs, etc from the Store link on top of the page.
    There is also good info here.
    http://60degreev6.com/showthread.php?t=24943
    SpudFiles
    Theopia
    Enjoy life online.
