3.1 Cams
  • 3.1cutlass
    • Feb 2007
    • 101
    3.1 Cams
    I have been watching threads around the board about diff. cams but not much on the 3.1. What would be a good cam to use as a dd but still make more power? I don't mind having it tuned. Also how hard of an install is a cam? What is involved?
    • 9191
    Crane and Comp 260 grinds are both good for an otherwise stock engine. Tuning wouldn't necessarily be required, although you will always get more out of the cam with proper tuning.
    As far as install, it is MUCH easier to install a cam with the engine out of the car. People have done it with the engine in the car, but to me, I would much rather just pull the engine and work on it on a stand than try to lower the cradle and then install the cam while confined to the wheelwell.
    • loner666
      • Oct 2006
      • 435
      try doing the cam in car from the top..im kinda wish i went thru the bottom cause is really sucks this way
      Best 1/4mile ET - 12.9
      Best 1/4mile MPH - 111
      1997 Ford Ranger Splash
      Daily Driver
      • 3.1cutlass
        • Feb 2007
        • 101
        i like the comp cam. I think that is the one i will get. Now to figure out installing.
        • PCGUY112887
          • Feb 2006
          • 1067
          How do you do the cam from the top? There is no room to slide the cam out.
          SpudFiles
          Theopia
          Enjoy life online.
          • 3.1cutlass
            • Feb 2007
            • 101
            ya i want to know that too. It seems like the least hassle would be to do it through the wheel well.
            • PCGUY112887
              • Feb 2006
              • 1067
              Ehh I dunno, the cam comes out right smack dab where your fender making it impossible to get out without having the engine out, or dropping the subframe so the engine drops almost to the ground so you can get it out.
              SpudFiles
              Theopia
              Enjoy life online.
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                People drill a hole in the inner fender to get the cam out. Then plug it later with a rubber or plastic press in plug.
                  Live life 3.7mi at a time
                  • 4555
                  You can get the same grind from Delta for less than half the price. I got a 260 re-grind for $59, new are $89, lifters from them are $40.
                  • 3.1cutlass
                    • Feb 2007
                    • 101
                    That was my next question. Does this cam require any other engine mods?
                      • 4555
                      The 262, not really, I would suggest porting, and if you want to take FULL advantage, a tune. Call Delta and tell them what mods you have now, and they will recommend a grind.
                      • 3.1cutlass
                        • Feb 2007
                        • 101
                        ok thanks
