oil pressure concerns
  • v6Mongo
    • Feb 2007
    • 24
    Just bought a 91 Firebird and it runs sweet. I noticed that the oil pressure stays pegged at 80 tho'. This doesn't seem right. Anyone have experience with this. Is it a guage problem, engine problem, or no problem?
    thanks,
    Bruce
  • sharkey
    • Jun 2004
    • 2061
    well, the oil pressure wouldnt actualy be at 80psi, the factory pressure releif in the oil pump is at 70psi. id try changing the sending unit, they are common for failures in older cars. if that doesnt do it, check out the wiring (run a resistance test from behind the cluster to the sender) to make sure you have no breaks in it. if all that ckecks out, its gonna be the cluster.
      • 9186
      The problem most likely is the wrong sending unit. There is a sending unit for the idiot light (short and stubby) and one for the gauge (longer). If the idiot light sender is installed, it is basically just sending and on/off signal to the gauge, in which case the gauge will show pegged high or zero.
      • 86euro
        • Dec 2006
        • 218
        Does the pressure reading build up as you crank the engine, or does it just peg as soon as the key is turned on?
        • v6Mongo
          • Feb 2007
          • 24
          Thanks guys. I'll be checking that stuff soon.
          • 85_Olds_Ciera
            • Aug 2007
            • 259
            Originally posted by sharkey View Post
            ....id try changing the [oil] sending unit, they are common for failures in older cars. if that doesnt do it....
            Uh...lower pressure readings?
            • v6Mongo
              • Feb 2007
              • 24
              Unit seems grounded or something - needle just goes whoop! to full right when the key is turned on.
              • X11_STE
                • 386
                Bad sending unit. Cheap easy fix.
                Tuning a car is full of compromises. You must decide if you are willing to give up either reliability, performance, or a whole load of cash. Also remember that repairs will seem to come up much more often as you strive for even more performance
