3500 MAP sensor adapter
  • whitelightnin04MC
    • Nov 2006
    • 159
    I swear I remember seeing on here a link to a site that sold the 3400 to 3500 map adapter. I don't mind cutting my harness, but I'm going to have to find a pigtail. The last time I went to the j-yard, they didn't have much of a selection. I guess I could try the dealer, but they aren't usually helpful when it comes to harness connectors.
    Someone please tell me that I wasn't imagining things. I've been searching the board for the past ten minutes and haven't been able to find it.
    • 9179
    This is what I found...
    http://www.60degreev6.com/showpost.p...22&postcount=1
    • whitelightnin04MC
      • Nov 2006
      • 159
      Thanks. I had found that topic, but I swear I had seen another one that had a link to a site that sold the adapters.
      • whitelightnin04MC
        • Nov 2006
        • 159
        I FOUND IT! Thank you Isaac Hayes. The place is called EFI Connection.
          What did I do now? lol I guess I sent you that link a while back? A 98+ cavalier has that style MAP and pigtail. And yes EFI connection you can get the pigtail, just got to make sure it's the right one, several look the same but have a notch on the wrong side of the plug. I think the LS1 there in that link is the right one, based on color.
          This should interface with the stock map connector, if you want to make an adapter without modifying the existing wiring. The 3 prong female of course. You'll need the pins for it too. Not sure which size wire or if you need those rubber sealers with it. http://www.eficonnection.com/eficonn...atherpack.aspx
