need pinout for 3400 grand am
  • darkroom
    • Feb 2004
    • 19
    Does anyone know where or could they provide me the pin out of the 2000 grand am 3400 motor. i bought a clipped pcm harness for the 3400 for cheap. i'm trying to use the haynes manuel but there are more wires on the manual then on the pcm harness. thanks
  • v6h.o.
    • 1418
    Powertrain Control Module (PCM) Connector C1
    Connector Part Information
    1219111
    80-Way F Micro-Pack
    100 W Series, Sealed (BLU)
    Pin
    Wire Color
    Circuit No.
    Function
    1
    WHT/BLK
    2762
    Transmission Fluid Temperature (TFT) Sensor Ground
    2-3
    Not Used
    4
    LT GRN
    1222
    1-2 Shift Solenoid Valve
    5
    DK BLU
    473
    High Speed Fans Control
    6
    DK GRN
    335
    Low Speed Fans Control
    7
    BRN/WHT
    633
    CMP Sensor Signal
    8
    PPL/WHT
    430
    3X Reference High
    9
    LT BLU/BLK
    647
    24X CKP Signal
    10
    BRN
    2704
    MAP Sensor 5 Volt Reference A
    11-12
    Not Used
    13
    ORN/ BLK
    469
    MAP/ECT Sensor Ground
    14-15
    Not Used
    16
    BLK/WHT
    451
    PCM Ground
    17
    BLK
    2760
    IAT Sensor Ground
    18
    Not Used
    19
    PPL
    1500
    Ignition Wake Up
    Ignition Positive Voltage (Hot in Run/Accy/Start)
    20
    ORN
    480
    Battery Positive Voltage
    21
    Not Used
    22
    PNK
    1224
    Trans Fluid Pressure Switch A
    23
    Not Used
    24
    Not Used
    25-27
    Not Used
    28
    TAN/WHT
    1669
    HO2S 2 Low
    29
    TAN
    413
    HO2S 1 Low
    30
    PPL
    420
    TCC Brake Switch Input
    31
    BLK
    2753
    EGR Pintle Position Sensor Ground
    32
    GRY
    435
    EGR Valve Control
    33
    DK BLU
    496
    Knock Sensor (KS) Signal
    34-37
    Not Used
    38
    LT GRN/WHT
    1749
    IAC Valve B High
    39-42
    Not Used
    43
    BLK
    1744
    Fuel Injector #1 Control
    44
    YEL/BLK
    1223
    2-3 Shift Solenoid Valve
    45
    PNK/BLK
    429
    AIR Valve Control (w/California Emmissions)
    46
    PNK/BLK
    1746
    Fuel Injector #3 Control
    47
    LT GRN/BLK
    1745
    Fuel Injector #2 Control
    48
    RED/BLK
    453
    3X Reference Low
    49-52
    Not Used
    53
    TAN/BLK
    424
    Bypass Control
    54
    WHT
    423
    Ignition Control (IC)
    55
    DK GRN/WHT
    817
    Vehicle Speed Signal Output
    56
    BLK/WHT
    451
    PCM Ground
    57
    BLK/WHT
    451
    PCM Ground
    58
    PPL
    1807
    Class ll
    59
    Not Used
    60
    BLK/WHT
    451
    PCM Ground
    61
    BLK
    2752
    TP Sensor Ground
    62
    DK BLU/WHT
    1231
    Automatic Transaxle Input Shaft Speed (A/T ISS) Low
    63
    RED/BLK
    1230
    Automatic Transaxle Input Shaft Speed (A/T ISS) High
    64
    YEL
    400
    VSS High
    65
    PPL
    401
    VSS Low
    66-67
    Not Used
    68
    YEL
    772
    Transaxle Range Switch B
    69
    YEL
    492
    MAF Sensor Signal
    70-71
    Not Used
    72
    DK GRN
    83
    Cruise Disable/Inhibit Control
    73
    BLK/WHT
    845
    Fuel Injector #5 Control
    74-75
    Not Used
    76
    DK GRN/WHT
    428
    EVAP Purge Valve Control
    77-78
    Not Used
    79
    YEL/BLK
    846
    Fuel Injector #6 Control
    80
    BLK
    2751
    AC Pressure Sensor Ground
    Powertrain Control Module (PCM) Connector C2
    12191111
    80-Way F Micro-Pack
    100 W Series, Sealed (CLR)
    Pin
    Wire Color
    Circuit No.
    Function
    1
    Not Used
    2
    WHT
    1310
    EVAP Vent Solenoid Valve Control
    3
    DK GRN/WHT
    465
    Fuel Pump Relay Control
    4
    RED
    1676
    EGR Valve Ignition Positive Voltage
    5
    BRN/WHT
    419
    MIL Control
    6
    Not Used
    7
    LT BLU/WHT
    1747
    IAC Valve A High
    8-9
    Not Used
    10
    PPL
    412
    HO2S 1 Signal
    11
    PPL/WHT
    1668
    HO2S 2 Signal
    12-15
    Not Used
    16
    WHT
    776
    Transaxle Range Switch P
    17
    RED
    1226
    Trans Fluid Pressure Switch C
    18
    BLK/WHT
    771
    Transaxle Range Switch A
    19
    TAN/BLK
    231
    Engine Oil Pressure Switch Input
    20-22
    Not Used
    23
    Not Used
    24
    PNK
    239
    Ignition Positive Voltage (Hot in Run/Bulb Test/Start)
    25
    LT GRN
    432
    MAP Sensor Signal
    26
    YEL
    410
    ECT Sensor Signal
    27
    RED/BLK
    380
    A/C Pressure Sensor Signal
    28
    BRN
    1456
    EGR Pintle Position Signal
    29
    GRY
    23
    Generator F Terminal Monitor
    30
    BRN/WHT
    2702
    EGR Valve 5 Volt Reference A
    31
    Not Used
    32
    GRY
    2709
    FTP Sensor 5 Volt Reference A
    33
    GRY/BLK
    2701
    34
    GRY
    2700
    A/C Pressure Sensor 5 Volt Reference B
    35
    BLK
    2759
    FTP/Fuel Level Sensor Ground
    36-38
    Not Used
    39
    DK GRN/WHT
    459
    A/C Compressor Relay Control
    40-41
    Not Used
    42
    LT BLU/BLK
    844
    Fuel Injector #4 Control
    43
    Not Used
    44
    LT BLU/BLK
    1748
    IAC Valve A Low
    45
    RED/BLK
    1228
    Pressure Control Solenoid High
    46
    LT BLU/WHT
    1229
    Pressure Control Solenoid Low
    47-48
    Not Used
    49
    LT GRN/BLK
    444
    IAC Valve B Low
    50
    TAN
    472
    IAT Sensor Signal
    51-54
    Not Used
    55
    DK GRN
    890
    FTP Sensor Signal
    56
    GRY
    773
    Transaxle Range Switch C
    57
    DK BLU
    1225
    Trans Fluid Pressure Switch B
    58
    BRN
    1174
    Engine Oil Level Switch Input
    59
    LT BLU/BLK
    396
    Cruise Engaged Input
    Cruise Status
    60
    Not Used
    61
    RED
    225
    Generator L Terminal Control
    62
    Not Used
    63
    YEL
    657
    64-65
    Not Used
    66
    DK BLU
    417
    TP Sensor Signal
    67
    Not Used
    68
    YEL/BLK
    1227
    Transaxle Fluid Temperature (TFT) Sensor Signal
    69
    PPL
    1589
    Fuel Level Sensor Input
    70
    RED/WHT
    812
    24X CKP Sensor Battery Positive Voltage
    71
    Not Used
    72
    RED/WHT
    812
    CMP Sensor Battery Positive Voltage
    73
    BLK
    407
    CMP Sensor Ground
    74
    BLK
    407
    CKP Sensor Ground
    75
    BRN
    436
    AIR Relay Control (w/California Emmissions)
    76
    Not Used
    77
    Not Used
    78
    BRN
    418
    TCC PWM Solenoid Control
    79-80
    Not Used
    Colin
    • darkroom
      • Feb 2004
      • 19
      Thanks for the help
