New underdrive pulleys
  • 95Grand-Am
    • 268
    Has anyone used one of these for racing? My concern is that it won't control the harmonic of the engine at high rpms being as light as it is. I don't want to give up durablity for a few pound of rotating weight. So if some one has used one, I would like to hear your thought on how well it worked.
    • mfuller
      Mr. Common Sense
      • Nov 2003
      • 374
      I have had a FFP pulley on my 3400 Alero for years, and FWIW, it held up to the punishment of open track days (road course).
      Matt
      • blackbombshell95
        Kaiō-ken X 10
        • Jun 2004
        • 1386
        I was sort of wondering the same thing.
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
        • torq455
          If I only had money!!!
          • 1615
          pisshh, it's fine. i have two no problems. know another guy making over 400 hp that shifts at 7200 rpm that looks at his bearings every year and no sign of problems. i wouldn't worry about it. there are many more 660's that have them than you think.
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
          • 95Grand-Am
            • 268
            Did they have the engine balanced or were they using stock balancing. How often do they turn that many RPMS, If I run a 100 lap race that 200 times in about an hour. More details please.
            • torq455
              • 1615
              #21
              no stock bal. very often, street driven and many 1/4 miles shots. well now you're talking all out racing. i wouldn't worry about that 8-10 ish HP you'll gain. that kind of racing and power plus high rpm on a regular basis i wouldn't go without a damper. lower rpm and power under 300HP i feel is reliable. i wouldn't bother with a UD pulley if i were you. not worth it if it should happen to ruin an engine for only a $125 and 8 HP!
              Andy
              • Sidewinder
                • May 2006
                • 240
                #22
                Sweet, glad to see that someone took the reins once FFP stopped production. I was wondering if this would be a good place for me to start modding my engine next spring? I'm thinking about getting both the UD pulley and the alt pulley. Would this be ok with sounds systems as well?
                • blackbombshell95
                  Kaiō-ken X 10
                  • Jun 2004
                  • 1386
                  #23
                  Yes that would be fine with a sound system. You might consider also upgrading your alternator/battery system ground/power wire. Just replace with a larger gauge. This will help your sound system and prevent your lights from easily dimming
                  • Sidewinder
                    • May 2006
                    • 240
                    #24
                    Thats a good idea, thanks. I'm thinking I'm going to start with those first before doing anything else on my car.
                    • torq455
                      • 1615
                      #25
                      get a 1/2 farad capacitor.
                      Andy
                      • blackbombshell95
                        Kaiō-ken X 10
                        • Jun 2004
                        • 1386
                        #26
                        Anyone know how much a FFP UDP pulley weights? I want to compare to the MRZ one.
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          #27
                          I dont know how much it is, but I'm pretty MRZ weighs less than the ffp.
                          • torq455
                            • 1615
                            #28
                            MRZ has cutouts that would make it lighter, but not for much gain if any .
                            Andy
                            • RedBird
                              Aka Mr. 5th Motor
                              • Sep 2006
                              • 426
                              #29
                              it has cutouts, plus it doesn't have the 3/8" of aluminum added to the front of the pulley(or however much it is), so both those things cut down on weight.
                              Cammed 3400 --> 224whp 210wtq
                              Cammed 3500 --> ???
                              1 of 5 3500 J-Bodies
                                good point, MRZ's is thinner.
