SBC rods
  • kwhauck
    Olds Sleeper
    • Aug 2006
    • 379
    SBC rods
    Well I was doing some research but couldn't come up with any thing conclusive.....
    1. Which SBC chevy rods?
    2. How to I narrow them and how much?
    3. Does Crower still make the already narrowed ones?
    Thank you, Kyle
    Live life 3.7mi at a time
    • 4555
    It's in the site articles. They are 327 small journal rods, and the small ends need bushed, measurements are there too. I would link, but I'm still getting lost here with the new layout.
    • ezrollin
      • 205
      Im not sure , think you can get small journal powered metal rods now,which would be better and probably cheaper.
        • 4555
        Our stock rods are powdered.
        The only reason to go to SBC rods is because it's a cheap alternative to custom h beam forgings made for a 660.
        I plan on making some programs at the CNC shop to mod the SBC rods, as well as experimenting with some billet aluminum h-beams (if the bottom of the bore doesn't get in the way).
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          Our stock rods are NOT powder metal. They are true steel forgings. There is no need for changing them unless you are building a racing motor. I seriously doubt anyone here is making the power required to break them. If anyone is breaking them I would bet money the motor has seen detonation.
            • 4555
            I have only seen them bent. I thought I read somewhere that they are powder forged, and latter 660's have full forgings?
              the newer engines (3500 and 3900) have forged powdered steel.. all the older ones are true forged steel.
              • Badassoldspower
                • May 2006
                • 17
                Hello but to some of you I am new to and others not, my name is Kenny, I also would like to know about how to entirely beef up my 3400 block which will soon get 3500 P&P heads, and P&P Upper/lower intakes.
                • ezrollin
                  • 205
                  I agree, I only suggested the powered metal because I thought 327 rods might be hard to find.I've read many places that that rpm was the killer of rods,not horsepower.
                  • geoffinbc
                    • 5831
                    Yes that is true. RPM does kill rods but for the 99% of people driving on the street our motors are going to spin below 7000RPM which is where the stock rods are limited. Power output will kill rods eventually but again no one here is making enough power on a regular basis to brake stock rods. Curtis is probably at the limit of stock rods. If you are breaking or bending rods and not making a good deal more than 350HP then you are more than likely having detonation problems, and NO rod will last under detonation.
                      • 4555
                      My stock rods survive TWO extreme detonations(like a cannon exploding). The bearings were crushed like a penny on a train track. I haven't taken them out yet after the last time, hmmm.....
                      • geoffinbc
                        • 5831
                        Well then there it testament to stock rod durability. I rest my case and will continue to emphasize the strength of these motors. In you case it was probably bearing crush and movement of the main cap that saved the rods.
                        • kwhauck
                          Olds Sleeper
                          • Aug 2006
                          • 379
                          well if I stick with the stock rods, do you think i should have them cryo-hardened, shotpeened, both?
                          I planning on making 400+ hp on 12-15psi..........
                            • 4555
                            Shotpeening will strenghten them quite a bit. The smoother the surface, the harder it is for stress cracks to form from irregularities.
                            • 85_Olds_Ciera
                              • Aug 2007
                              • 259
                              ...and NO rod will last under detonation.
                              Years ago, I knew of a 8V-71 DETROIT DIESEL ENGINE that had a busted crank...due to lugging it...I think the rod was OK
