3400 build
  • montess408
    • May 2006
    • 391
    3400 build
    hey i am building a 3400 mostly stock replacement and a 75 shot i was thinking on putting 1.6 rockers and better valve springs so are 3500 valve springs better that the 3400 one or will i have to go aftermarket ?
    and i was thinking on building headers but i read somewherea that if yuo get two 3500 rear manifolds its eazy to run duals now are the 3500 manifold alot better flowing than the 3400 ones or am i better of building headers ?
    thanks guys
  • bjornmk1
    • Nov 2006
    • 266
    I'd say build headers.
    I don't know on the valvesprings..but the ls6 spring will do the trick
    and they are pretty cheap/easy to get.
    nothing's impossible-it's just a mindset
    • JMo60
      • Oct 2005
      • 300
      looks like you are looking at a similar set-up to my car. I have 3400 with milzy stg 1 cam (dont recomend it) and S&S headers.. you can use these headers in N and some W body cars. Im using a Nitrous Express 75 shot (main-line efi kit). I would recomend gettin a slightly better kit, while mine worked out well, it would have saved a lot of time and headache to spend a few more dollars and get everything you need..
      by the way, im using LS-1 valve springs
      94 Grand Prix
      • PCGUY112887
        • Feb 2006
        • 1067
        If 3500 springs are indeed better, I have set with 10k miles on em that I'll give to ya for cheap!
        SpudFiles
        Theopia
        Enjoy life online.
        • johnnymossville
          • Jul 2007
          • 255
          LS6 springs are the way to go and you can run them with your stock retainers and locks. Stock 3400 rockers are 1.6 roller fulcrum. I am running two front 3500 manifolds as they exit straght down and you can run individual down pipes. Flowmaster makes a y-collector to merge two downpipes into one (2.5" or 3"- Summit Racing and Jegs sell them). 3400 exhaust manifolds use a crossover pipe from the front to the rear just like your 3.1 and exit with one downpipe off of the rear manifold. If you are looking for a cam check out the store here (link is at the top of the page).
          • Blackrider
            • 131
            whats wrong with the cam?
            2006 G6 GTP MT6
            Vector Motorsports ECU
            Classic Performance 2.5 Inch Exhaust
            v6h.o. Downpipe
            Custom Intake
              johnny, got any pics of the manifolds installed and your downpipes?
              • montess408
                • May 2006
                • 391
                well i guess we have the same nitrous kit ! so your 3400 is mostlly stock then ? just the cam headers and nos how good do you run ? because my car is a z24 not as big of a car as a grand prix just to give me a example of what i can expect
                and johnny you say that stock 3400 rockers a re 1.6 so there is no need to go with a afermaket set then right ?
                and do you have pics of your manifolds with the down pipes ?
                  Yes 3x00 rockers are 1.6.
                  • johnnymossville
                    • Jul 2007
                    • 255
                    Sorry Isaac, just have a living room full of parts right now. I just ordered my cam and pushrods from the 6*60 store and Ben says it may take three weeks to get them. As soon as all of the parts get here I"ll start assembling everthing. I'll post pics as I go just in case anyone may be interested. 2000+ 3400 bottom end, 3500 heads/ LS6 springs, 3500 LIM, 3400 UIM, and I am going to order a 65mm Tb from the store also. I think that I am going to port match everything while I'm waiting for the cam. Can't wait to get it running!
                      3500 plenum!!! Why use 3400?
                      • johnnymossville
                        • Jul 2007
                        • 255
                        I would if I could get one cheap, I have no access to one around here. My 3400 is a 2000 so at least it's the better one. Anybody have a 3500 UIM reasonaly priced?
                        • JMo60
                          • Oct 2005
                          • 300
                          my car is running 13.80's right now with the 3400, headers, nitrous, and little useless stuff.. 13.80s is a bit tricky, id expect low 14's to start, then learning how to drive it you might see some high 13's. (its difficult to figure out when to spray, so that the wheels dont spin too much, but still early as possible)
                          I say i dont like the milzy cam, because it does not run any different than a stock cam car. if it does, it isnt by much.
                          94 Grand Prix
                            Did you try car-part.com for the plenum? Make sure to select the right years so you don't get a VVT 3500 plenum..
                            • johnnymossville
                              • Jul 2007
                              • 255
                              Thanks Isaac, found a few the and I might be able to get one. Thanks again.
