Fuel Rail Thread Size
  • viper15230
    • May 2006
    • 28
    Im running braided hose to my fuel rail on a 3100. I cant figure out what size the threads are I have tried many different sizes with no luck yet. I have tried 16 mm. 18 is my next option but that just seems to big what do you think?
    • 9190
    http://www.60degreev6.com/store/inde...d&productId=64
    • viper15230
      • May 2006
      • 28
      Well since fittings are available for 5 or 6 dollars, and I only need one and I would also like to keep the stock regulator, those are my reasons for not purchasing that.
      • sharkey
        • Jun 2004
        • 2061
        you cant just screw a typical an fitting into the rail, it wont seal. the fittings shown in the link above are custom made for the application cause nothing else works.
          Are you wanting to run new braided line to the fuel rail from the firewall, or do you want to tap off the shrader valve connection?
          • viper15230
            • May 2006
            • 28
            Im running it from the hard line by the firewall. I have the hard line to braided already hooked up and same for under the regulator. I just need the fitting to screw into the rail. Tried contacting the store last night to see if I could buy just he one side. Havent heard from them yet.
