Max Timing
  • ACAT
    • Aug 2007
    • 18
    Max Timing
    I have a .030 over 3100 ( 3200? ) w/ flat top pistons, 10.5 compression, stock roller cam, iron heads, edelbrock 4 bbl. intake, HEI distributor and stock exhaust manifolds. 1700 lb car. What total timing advance do you think I should run? What HP would you guess w/ this combo? I have room for some short headers, 12 in. runners. Would it be worth doing? How much HP? Thanks
    crank it up till it pings.. then back it off 2 degrees.. j/k
    28 degrees total should be fine, you could go higher if you are running premium but probably don't need it.
    HP.. maybe 140 or so @ the crank.
    what kind of car is this?
    • ACAT
      • Aug 2007
      • 18
      It is a mid-engine tube frame street rod. I'm @ 36 degrees advance already w/ no pinging on reg fuel. Engine is 2' from my ear so I should hear it. Guess I will try a little more. V8's seem to run this amount. My carb is rich so that may be allowing it.
      • 2.8RS
        Cone Murdurer
        • 196
        You might be seeing 150 at best I would guess. Stock 3.1s made about 140 if I'm not mistaken.
        00 Grand Prix GTP Daytona
        • sharkey
          • Jun 2004
          • 2061
          i run my motor around 36 total, its a bit less compression with a 260h cam. i have tried running as much as 42 degrees without pinging, but i dont really see any power gains above 38
            I think 36 or so is about on for the iron heads.
            • rsisbetter
              • Mar 2006
              • 151
              rev 8k rpm, and you'll see a gain.
              • torq455
                If I only had money!!!
                • 1615
                you'll only gain power if the engine needs more spark lead. you can over-time it w/o gains or even loose power w/o any knock. me, i have 30 with 91 octane and rarely get knock, but that's a mid third gear (auto) hot day run. however, i do have a mostly stock 3.1 with 150K miles.
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
                  Mine's making most power at 25 degrees advance, but that's with a big cam, really good heads and upped compression.
