Fiero computer swap Questions PICS
  • 3XTurboAgain
    • Jun 2007
    • 222
    I need to know how to put a 3.1 computer in this car. The 2.8/th125 is coming out and i would like to tackle the computer layout while the engines being built. It's going to be turbocharged w/ MPFI computer.
    [IMG][/IMG]
    The first picture has 2 black plugs and a white square plug. The 2 black ones came from the computer and there are 2 black plugs that come from the center console that the White square plug came from. Picture 2 shows the center console plugs.
    Does anyone know where i go from here? Is this for sensors and switched igntion, gauges, to the dash? I imagine i drop the whole harness in, hook up the constant power and splice certain pin # from back of 3.1 computer to everything else? gauges, switched ignition, fan relays, check engine light... i need help so we're just trying to absorb as much info as possible on the computer swap.
  • 2.8RS
    Cone Murdurer
    • 196
    You can run the 3.1 with a 2.8 computer. I will be doing it. The harness is different in a couple of places. The 3.1 is MAP and the 2.8 is MAF so the harness is different. You may have to swap the harness too if you go that route.
    00 Grand Prix GTP Daytona
    • sharkey
      • Jun 2004
      • 2061
      2.8l in the fiero is not maf, its speed dencity with a map sensor.
      • 3XTurboAgain
        • Jun 2007
        • 222
        Im trying to get rid of the whole distributor deal... need to run a crank sensor and coil packs like a 1990 FWD 3.1 so i dont see any way to use the 86 fiero GT computer or engine harness...Im actually using a 99 3400 top end with a Turbo grand prix chip ive had lying around. there obviously has to be a decent amount of wire splicing to get this computer hooked up...right? will someone step forward here?! I know its been done and i dont think there are any writeups because it was either such a pain in the ass or it was way too easy... thanks guys
        • sharkey
          • Jun 2004
          • 2061
          pretty much you need to hack the stock pcm plugs off and wire the 7730 ecm plugs onto your harness. the best way to do it is get wiring diagrams for both , and one at a time pull the pin out of the fiero plug and put it in the correct spot on the 7730 plugs. its time consuming, but the best way.
          you can run your stock computer with dis, the gm dis has the same connections at the computer as the distributor does. with a little bit of tuning, it works fine.
          • 3XTurboAgain
            • Jun 2007
            • 222
            OK, will i have to splice less wires if i use the new wiring harness with the 7730? Otherwise, using the fiero harness is going to make for a lot more splicing...right? I have the pin layouts for both computers im just trying to make it as straight forward as possible. By the way thanks for the help everyone.
            • 85maro
              • Sep 2006
              • 140
              Don't get scared off by harness repinning, I converted my '870 to a '165 and it wasn't a hard swap. Hardest thing so far has been trying to understand the dissasembly of $1F (the '870 mask) I had to do to find the stock maf scalars.
              Save yourself some $$ and repin it. You can use the Fiero harness, just run the dist. (rpm signal) wires to the crank sensor. I assume you are using a 3x00 block & crank? Otherwise a crank sensor is pointless.
              • 3XTurboAgain
                • Jun 2007
                • 222
                OK guys im really new to this so please bare with me...i have the whole engine harness out now. Wait so the plugs for the crappy distributor are the same for the ICM? i dont understand... if i remember correctly , the ICM has 3 plugs. one for crank sensor, power,...and a 3 wire plug i think... Sorry im just a bit confused, im just tryin to get through all this. Thanks
                • 85maro
                  • Sep 2006
                  • 140
                  There should 2 plugs on the ignition module. The pinouts for the rpm signal wires should be the same on the 3.1 and fiero ecms. Are you using a 3x00 block and crank? Otherwise you'll need to have the block machined to use the dis crank and sensor.
                  • 3XTurboAgain
                    • Jun 2007
                    • 222
                    Im using a 3.1 block from a 1991. Heres what i found so far.
                    1988 Fiero GT
                    A1 Fuel Pump
                    A2
                    A3
                    A4 EGR Valve
                    A5 SES light
                    A6 IGN
                    A7 TCC or Shift LT
                    A8 Serial data
                    A9 Diag Term
                    A10 VSS input
                    A11 MAT sig
                    A12 GND
                    B1 Battery
                    B2
                    B3 EST ref Low
                    B4 EST CTRL
                    B5 Dist Ref
                    B6
                    B7
                    B8 A/C clutch sig
                    B9
                    B10 P/N SW
                    B11
                    B12
                    C1
                    C2 A/C relay control
                    C3 IAC "B" Low
                    C4 IAC "B" high
                    C5 IAC "A" high
                    C6 IAC "A" low
                    C7
                    C8
                    C9
                    C10 Coolant Sig
                    C11 MAP sig
                    C12 Map Sig
                    C13 TPS sig
                    C14 5V ref
                    C15 Inj 2,4,6 "B"
                    C16 Battery
                    D1 SYS GND
                    D5 EST Bypass
                    D6 O2 ground
                    D7 O2 sig
                    D8 EGR Diag SW
                    D12 CLTS-TPS ground
                    D13 Map-Mat ground
                    D14 Inj 1,3,5 "A"
                    D15 Inj 1,3,5 "A"
                    D16 Inj 2,4,6 "B"
                    • 3XTurboAgain
                      • Jun 2007
                      • 222
                      1991 3.1L ECM wiring
                      1 IAC
                      2 IAC
                      3 H/D Cooling fan relay
                      4 EGR sol (A) control
                      7 IAC
                      8 IAC
                      9 Cooling fan control
                      10 Canister purge
                      11 Detonation Sensor
                      12 A/c comp Ctrl
                      16 O2 sensor high
                      19 EGR sol (B) control
                      20 Fuel pump relay Mon
                      22 O2 sensor low
                      1 SES ind control
                      3 Diag Input
                      5 Data in/out
                      7 TCC
                      8 SPD SENS output
                      10 Ign power
                      2 VSS input
                      3 Bypass control
                      4 IAT sensor Input
                      5 Sensor ground
                      6 Ground
                      7 5v Reg (MAP and A/C Pres Tran)
                      8 VSS input
                      9 Spark Timing
                      10 Sensor Ground
                      12 5V ref TPS
                      13 EGR sol (c) control
                      14
                      15 TPS input
                      16 Coolant temp input
                      17 A/C on input
                      20 2nd Gear input
                      21 A/C Pres Sig
                      22 MAP input
                      3 INJ control
                      4 Ground
                      6 3rd Gear input
                      7 Fuel pump relay
                      9 Inj control
                      10 Ground
                      11 Trans PostN input
                      12 Ground
                      13 Dis Pulse Ref hi
                      16 P/S pres input
                      17 Battery power
                      19 DIS PULSE Ref Lo
                      22 4th gear input
                      • 3XTurboAgain
                        • Jun 2007
                        • 222
                        So i just have to repin everything and use parts of a 3.1 harness...sweet. its going to be reallll fun.
                        • merlot566jka
                          • Nov 2006
                          • 570
                          fiero.nl 7730 ecm conversion, been there, got the dis to prove it. read about it there. darth ahs the charts and conversion tables on his website
                          2012 Chevy Sonic Turbo 6spd
                          • Joseph Upson
                            This is the "bestest" forum for anything 60 degree V6 engine related, but what you are trying to do is a lot easier than what you think and has been detailed on the Fiero forum, you only need to relocate the pins to the proper terminals in the plug for use with the 730 ecm, the only plugs you'll need to change are those related to the sensors, in your case if you are using aluminum heads the 3.1 Beretta code will have you on your way in no time;
                            http://www.fiero.nl/forum/Forum2/HTML/079574.html
                            • 3XTurboAgain
                              • Jun 2007
                              • 222
                              Hey i havnt checked this thread in a while!! thanks a lot for showing me Darth Fiero layouts, i guess the Baretta code it is! Can anyone tell me what C203 is? Are they the connectors on the center console in my picture 2?? Thanks to everyone for all the help!
