93 Cutlass Ram-Air Questions
  • El_Diablo
    STFUniversity
    • 917
    #46
    and they're only $65 shipped for a magnaflow cat
    no engines need backpressure, its a myth, its all about flow vs. velocity, same idea with porting heads, the idea is to have no backpressure at all but a balance between flow and velocity for what your trying to achieve
    • Stonedified
      • Oct 2007
      • 30
      #47
      ahhh i see.
      yeah, my car hasnt been checked for emissions since it left the showroom floor. the noise could be a problem, small town cops like to give tickets for noise. i do need to get rid of the stock cat though. maybe use a high flow, maybe a resonator in place...maybe have a friend quote me on an entire mandrel bent exhaust...
      1993 Cutlass Supreme SL Coupe - 3.1 MPFI
      Performance:
      -Cone Air Filter. that's it.
      • blackbombshell95
        Kaiō-ken X 10
        • Jun 2004
        • 1386
        #48
        What I want to know is how you got a 2.8 60ft!!!!
        For a car do get that you need to be able to burn out like crazy.
        You should be able to get a 2.3 60ft and your times should be low to mid 17 sec in the 1/4.
        Empty your trunk also. Im guessing your trunk is loaded with heavy stuff
        02 GTP - 90* > Failboat
        www.blackbombshell95.com
        • Stonedified
          • Oct 2007
          • 30
          #49
          nothing in my trunk....not a huge burnout, just enough to see some smoke...or do you mean burnout off the line? because my tires slipped like none off the line
          Performance:
