3800 Alt Pulley
  • Sidewinder
    • May 2006
    • 240
    3800 Alt Pulley
    I've heard that the 3800 alt pulley will work on 3100 from your guys as well as from a few other people. My questions about this:
    1) Will this actually reduce load and increase rpms like I've been told? How much of a difference does it make?
    2) Are there any ill effects crated by doing this?
    3) Will I need a new belt?
  • silvergtjrad
    uber slow grand am
    • Feb 2007
    • 302
    Yes, the alternator pulley will fit, but I believe its the same size as ours. ZZP sells an underdrive alt. pulley that will fit a grand am 3400, so I dont see a reason why it wont fit on an alternator from a 3100. The stock belt will still work with the underdrive pulley as well. Voltage will drop slightly (zzp claims something around .2 volts) but you can solve that by running a thicker wire from the positive terminal of your alternator to the battery.
    • El_Diablo
      STFUniversity
      • 917
      i know this prolly sounds idiotic, but do you have an actual picture of the pulley and did you feel anything from it?
      • silvergtjrad
        uber slow grand am
        • Feb 2007
        • 302
        I actually do have a picture of the pulley, and no you cant feel any gains. There arent too many "simple" mods that you can actually feel. The other day I did a WOT run with a 35 shot of nitrous, and flipped the arming switch on and off a couple of times. I could bearly tell a difference in acceleration, and it was probably only because I knew when it was on or off.
        The ZZP pulley is on the alternator, and I am holding the stock one against it for size comparison
        • El_Diablo
          STFUniversity
          • 917
          didn't notice the engine rev's change at all? i didn't really mean did it feel like you were going faster, sorry, im an idiot with how i word things sometimes
          does it have the stupid "14% underdrive" labeling on it?
          • silvergtjrad
            uber slow grand am
            • Feb 2007
            • 302
            No, I havent noticed any change at all. Its only $60 IIRC and I guess all of the small mods add up at some point. I would have to go look to see if it says that on the pulley.
            • El_Diablo
              STFUniversity
              • 917
              i might end up getting it, kinda interested in the water pump pulley aswell and what the details on it are.... dont want to lose to much cooling ability
              i already have an FFP UDP but im trying to get loss down to a minimum
              • silvergtjrad
                uber slow grand am
                • Feb 2007
                • 302
                the water pump pulley doesnt fit, its for a grand prix.
                • El_Diablo
                  STFUniversity
                  • 917
                  its in the ga section....?
                  • Sidewinder
                    • May 2006
                    • 240
                    Ah ok, sounds almost as if its really not worth it to spend time on this right now. I'll maybe looking into it later, but right now I'm saving up for top swap parts.
                    • Monzsta
                      • Jul 2007
                      • 132
                      3400 swap underway.. 6 days and counting down...
                      Sig don't work... grumble...
                      '97 Chevy Lumina DHP tuner, k&n, Shift kit.
                      IN PROGRESS: 3400 swap, 3,000 stall converter, 2.5" exhaust
                      '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
                      1/8 mile 9.72@75 mph, 2.0 60 foot
                      • El_Diablo
                        STFUniversity
                        • 917
                        and this has to do with the thread how?
                        • Monzsta
                          • Jul 2007
                          • 132
                          Ah, umm.. we both drive white whales? lol!
                          • Sidewinder
                            • May 2006
                            • 240
                            LOL I actually forgot about this thread and missed that. I'm actually doing a 3400 TOP swap. So I'm just swapping the heads and the upper and lower intake manis as well as the TB.
                            I like my white 'whale' though, I don't consider it a whale really though. These cars handle better than some small cars I have driven IMHO. I like them too because for me, this thing is unique, no one in my area touches Luminas.
                            • Monzsta
                              • Jul 2007
                              • 132
                              Mine's strictly a beater. It has a serious paint delamination going on and I got it for almost nothing.
                              Why not swap the whole thing? I got my 3400 from Pull-A-Part, it was half hanging out of a 99 Grand Am. The only thing missing was the t/b. 1 hour later it was in the trunk of my Lumina headed home for $150.
