oil squirters
  • bjornmk1
    • Nov 2006
    • 266
    does anyone have (close up) pics from such block with
    those squirters ??
    nothing's impossible-it's just a mindset
      • 9189
      • zofo61
        Banned
        • Oct 2005
        • 436
        aint they perdy
        • El_Diablo
          STFUniversity
          • 917
          but how would one go about doing such on the rest of the block, is there even an oil passage that you could tap into for the rest of the pistons? and wouldn't you need to machine a surface like on the 3500 block?
          the easiest way it seems would be to drill and tap for mounting and just run a metal line to the other squirters
            • 9189
            DING DING!!! We have a winner!
            • El_Diablo
              STFUniversity
              • 917
              #21
              yes, but where do you recommend this line come from? lol, sorry but im not to familiar with the 660 internal oiling system yet
              • MidnightriderZ24
                • Jan 2005
                • 699
                #22
                heres what they look like... it looks like the block doesnt need to be machined, it looks like i can drill and tap into the oil gallery for the cam..
                [SIGPIC]
                12.268@117... 11's to come!
                • El_Diablo
                  STFUniversity
                  • 917
                  #23
                  when i said machined i mean to a flat mounting surface like they did from the factory
                  • MidnightriderZ24
                    • Jan 2005
                    • 699
                    #24
                    the mounting tab could be tweaked a little bit so it would be mounted. mounting this thing wont be a problem... ill talk to my guy whos gonna be doing my block work and see what he thinks
                    [SIGPIC]
                    • zofo61
                      Banned
                      • Oct 2005
                      • 436
                      #25
                      GM Part # Please....and Thanks
                      • geoffinbc
                        Iron Head Enthusiast
                        • 5831
                        #26
                        I don't think it would be possible to mount them on a 3400 block where would you get the oil supply from? There is no passage in the are it is mounted. You cant drill up into the block since you will come out in the cam tunnel where there is no pressure just an air space. I wonder if you could drill up on and angle and intersect the vertical oil gallery from the crank to the cam.
                        Hey brad is there any literature on the modifications to the 3500 and 3900 block to accept the squirters?
                          • 9189
                          #27
                          I could try asking my GM contacts about oil passage diagrams.
                            Live life 3.7mi at a time
                            • 4555
                            #28
                            That would be the shiznit.
                            • JohnnyReb
                              • Nov 2007
                              • 49
                              #29
                              How are we coming on these squirters? I've got my short block assembled but would like to add squirters if possible. I think for oil supply you can tap into the cam feed. I just got back in and cleaned up but I'll look tomorow but I THINK there is a oil feed that runs the length of the block right there in the middle. Below the cam.
                              • silvergtjrad
                                uber slow grand am
                                • Feb 2007
                                • 302
                                #30
                                Midnightriderz24, where are you getting the work done on your block?
