Should i bother porting?
  • el_roy1985
    • Apr 2004
    • 40
    Should I just cut out some of the 3400 gasket then? or would that not be a good idea?
    1996 Beretta, 3400/5 speed, internet Tune, FFP UDP, Billet/poly mounts, ported intake manifolds, WAI, 2.5" mandrel exhaust, Borla ProXS, Intrax, KYB, poly front end kid, welded a-arms, strut, shock and sub-frame braces.
    • Z26-T
      • Apr 2008
      • 486
      If you cut the "paper" gaskets to the red silicoln it's supposed to be equivalent to the metal 3500 UIM gaskets. When I ported my 3500 UIM I just did it to the 3400 gasket, but that's because i didn't port my lower.
      • el_roy1985
        • Apr 2004
        • 40
        Ok, thanks. Just wanted to make sure it wasn't going to weaken the seal on the "paper" gasket.
        Has anyone recorded any gains from just porting the UIM and the LIM?
        • IanSzgatti
          • Oct 2006
          • 519
          I had a 97 Malibu at one time, ported the upper and lower intake not once but twice and added a 56 mm TB. I noticed the results in throttle response and high rpm acceleration.
          About 2 weeks after all this put in your new 02 sensor. Nuthin like a brand new lighting fast 02 sensor to get that mixture nice.
