3.4 iron head timing cover on a 3500....
  • merlot566jka
    • Nov 2006
    • 570
    will it work? what about the harmonic balancer from the 3.4 iron head, will it fit the crank? will the water pump work with the 3500?
    im trying to retain the ac, alt and fiero brackets and i think using the old timing cover would help greatly. thanks for any help
    2012 Chevy Sonic Turbo 6spd
  • merlot566jka
    • Nov 2006
    • 570
    no one tried it yet? i figured id hear someone from tce or the mg crowd
    • CNCguy
      Bisong eater :P
      • 1017
      Well...
      I assumed someone would jump in here but I guess not. The RWD cover will bolt right onto the 3500 but you will have to plug the small coolant bypass hole just below the left water inlet to the block. It is about 5/16" diameter and you may get by with tapping it to 1/8" NTP or else welding it closed. The dampener will fit on with no problem. The only real issue will be any brackets that bolt to the heads since the FWD heads have different bolt pattern than the RWD heads.
      MinusOne - 3100 - 4T60E
      '79 MGB - LZ9 - T5
      http://www.tcemotorsports.com
      • merlot566jka
        • Nov 2006
        • 570
        ok, with that said, ill use the 3500's mumbo jumbo
          Live life 3.7mi at a time
          • 4555
          You don't need a dampener on the 3500 crank, they didn't come with one . But yes, the cover fits fine, I just tried it two days ago, but was unaware of the coolant hole needed to be pluged.
          The crank snout length and diameter were the same as well.
          • merlot566jka
            • Nov 2006
            • 570
            too late now, i orderd the a/c compressor and the alt today, 86 shipped for both...i love ebay.
            • CNCguy
              Bisong eater :P
              • 1017
              All three of the 3500s I have seen had a dampener. Instead of it being a cast unit, the outer pulley section is roll formed while the inner section is fabricated from a stamping and a machined hub. There is a rubber ring between the inner section and the outer ring. They did reduce the weight of the dampener but increased it's diameter.
              '79 MGB - LZ9 - T5
                • 4555
                So the pulley is the dampener now. I didn't notice a rubber ring when I was breaking down my 3500...
                You mean the rubber is under the rolled edge, and can only be seen from the back? It's at the shop, so I can only look at pics right now. Now you have me curios.
                  • 9189
                  On the FWD engines, the damper and pulley have always (well, at least since the serpentine belt) been integrated.
                    • 4555
                    So I can use the 3500 pulley/dampner on the 3.4 crank? This would clean the bay up a little more
                      Yes or a 3100/3400/3.1/2.8 since those pulley/dampeners are smaller in diameter than the 3500 one.
                        • 4555
                        Yeah, but I have a 3500 pulley sitting on the shelf next to all the 3500 parts
                        • CNCguy
                          Bisong eater :P
                          • 1017
                          The problem would be with the belt location. The belt would be closer to the engine and won't match the RWD WP, ALT etc. Also the 3500 dampener will hit the RWD cover.
                          '79 MGB - LZ9 - T5
                          • merlot566jka
                            • Nov 2006
                            • 570
                            what about oil pan and timing cover relation?
                              • 4555
                              The bottom of both are the same. That was the first concern when I test fit it.
