Valve Spring Removal?
  • zofo61
    Banned
    • Oct 2005
    • 436
    I bought a valve spring compress tool(lever) and want to know if there are any tricks to this before I screw something up. I have never done this so all input is appreciated. Pictures help as well.........anyone?
    Thanks
    Chris
    Live life 3.7mi at a time
    • 4555
    I don't like the lever type, never had good luck with them. The c-clamp syle is a little more expensive, but has better control. I've seen the c-clamp style at PepBoys for less than $40.
    • El_Diablo
      STFUniversity
      • 917
      got my craftsman "C-clamp" style for $20 plus tax, mine was actually free cuz my gf bought it for me for an early birthday gift
      • zofo61
        Banned
        • Oct 2005
        • 436
        Thats great.............I may look into that style as well....I figured out the lever and it works but its a pain cause the 3500 rocker stud is rather small...........hmmmmm.....anyway, not that difficult....and there was no blood shed as well..........goood times
        • 3100 MPFI
          • 1522
          are you doing the valve springs with the heads on the car, or off?
          If the heads are on the car, you will need an aircompressor and fitting to hold the valve up. Otherwise, your valve will drop down into the engine.
          If the heads are off the car, then you are good to go.
          You will also want a little magnet to get the keepers off of the retainer. Just makes it a little easier.
          Taylor
          1998 Lincoln Mark VIII
            • 4555
            You can also feed 1/4" rope into the chamber through the spark plug hole, and turn the motor over to have the rope hold up the valves. Just make sure you leave some sticking out to get it out when you are finished
            • zofo61
              Banned
              • Oct 2005
              • 436
              Motor is on a stand and the lever tool is a biatch. i am going to get the C clamp type when I put them back together with the LS6 springs. Any thoughtson seals and why do some shim the bottom of the spring?
              • johnnymossville
                • Jul 2007
                • 255
                With the LS6 springs you will have to run seals such as 2.2l ohv chevy ('91-'92) seals that have a smaller outside diameter than the stock seals because the LS6 springs won't fit over the stock ones. You will need to run seats so the springs won't eat up the head and the stock seats are part of the valve seal. Check out this thread because there are a couple of places posted to buy the seats at a good price.
                http://www.60degreev6.com/showthread.php?t=38539
                I believe they are LS6 seats and that you will have to grind out the center slightly so the seat will fit over the valve guide.
                • 19Cutlass94
                  • Apr 2005
                  • 770
                  yeah the LS6 seats you will have to bore them out to fit.
                  3400/Getrag 284 5spd
                  350/NV3500 5spd
                  2014 Chevrolet Malibu LS
                  • zofo61
                    Banned
                    • Oct 2005
                    • 436
                    There you go ...........glad I asked.........You guys are the shizle
                    • El_Diablo
                      STFUniversity
                      • 917
                      shouldn't be hard to modify the shims if you have a drill press
                      • zofo61
                        Banned
                        • Oct 2005
                        • 436
                        Dont have a press but I am pretty darn good with a drimmel. I got the clamp-style valve spring tool today at Sears and man what a difference a tool makes. The lever is going back in the morning for sure. Will be ordering the shims and seals as well.
                        • El_Diablo
                          STFUniversity
                          • 917
                          did you get it half off? i got an $80 torue wrench for like $40, a $30 digital multi-meter for $20 and a $25 bolt out kit for $10
                          135 before tax, i got it all for $64 total, gotta love craftsman sales thats the only reason i even went out today
                          • zofo61
                            Banned
                            • Oct 2005
                            • 436
                            Anyone who pays full price for Craftman tools....is the most impatient person on the planet...they are ALWAYS on sale!.....jeez.....kinda sounded like a woman there for a moment.
                              I just modified some of those LS1 spring seats to work, it takes like 10 sec with a die grinder.
                              Left is modified, right is stock
                              and yah, C clamp compressors are the best. Much safer and quicker than the jaw style.
