5.7 RODS VV. Stock
  • carsan57
    • Sep 2007
    • 18
    5.7 RODS VV. Stock
    I have a set of sbc rods i heard you can swap them out in a 3400. Are these rods stronger then the stock and how much work will it take to make them fit?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    You have to narrow the big end and bush the small end or get pistons made for smallblock pins.
    In no way is it worth it for anything under 300HP. Start to go higher than that and combined it with boost and then start thinking about it. Even at that you will be hard pressed to find someone with broken 660 rods due to power. They always break from seized bearings or detonation.
    • El_Diablo
      STFUniversity
      • 917
      only the small journal rods will work, not sure if you knew that or not
      • latemodelnewbee
        • Jun 2007
        • 227
        If you a set of factory small journal rods, get 327 rods there stronger than most 283. the early 283 rods(1957-1961) aren't as good but the later 283 used the same rods as the 327, 1962-1967. I have 2 sets of stock 327 rods they are in good shape just need resizing and new bolts, which doesn't a whole lot. just let me know if any one wants a set
        68 El camino 454 speed muncie 3.90 posi 12 bolt,
        80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
        60 Impala 2 door hardtop L79-327 T56 4.11 posi.
        83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
        91 Z34 now has a hm284. and belly pan in the works
        • zofo61
          Banned
          • Oct 2005
          • 436
          How much?
          • latemodelnewbee
            • Jun 2007
            • 227
            i was thinking like $75 for a set of 8 plus shipping and you can pick the best 6 for your motor. They will be out of the same motor, not miss matched.
