crane rocker stud problem
  • rsisbetter
    • Mar 2006
    • 151
    I purchased the crane gold rockers from another member on v6z24. i unexpectedly recieved some arp rocker studs, which to my assumption were the right ones for using them in a 3400. the issue i have is:
    1. the studs i recieved also do not directly thread into the stock rocker holes, the studs have a larger size threaded head end. I did not see anywhere that the stock holes must be drilled and retapped for these, is that right?
    2. bigger problem, when i slide the rocker over the top of the stud, the rocker body rests and rubs on the base of the stud...? not sure on this.
    so...what is the difference between using the 8mm, and 10mm studs?
    the ones i have look just like the ones i have, (besides actual diameter under assumption).
    i have a 2003 3400.
    do i need different studs, or is there supposed to be modification that i had not seen before?
    thanks
    cody
    • 9191
    03+ (I thought it was 04+, but maybe it was 03) heads went to a smaller 8mm rocker stud from the previous 10mm stud. Therefore, if the person who sent you the studs had pre-03 heads, then they would have had the 10mm heads. And they probably didn't even think about (or possibly know about) the difference.
    Not sure on the 2nd question, as I have never used these rockers, so I'm not sure what exactly you are talking about, nor if it is an issue or not.
    • latemodelnewbee
      • Jun 2007
      • 227
      The rocker arm won't go as far down the stud when you are installing them on the motor. The pushrods won't let the rockers go down that far with out opening the valves.
      68 El camino 454 speed muncie 3.90 posi 12 bolt,
      80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
      60 Impala 2 door hardtop L79-327 T56 4.11 posi.
      83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
      91 Z34 now has a hm284. and belly pan in the works
      • rsisbetter
        • Mar 2006
        • 151
        hmm, well i still havent heard a reply from the seller, but i'll keep searching
        thanks
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          Arp sells the studs you are looking for. They have an 8mm bottom and 3/8" top
          • rsisbetter
            • Mar 2006
            • 151
            ^ thanks, that's what i'll need, assuming i wont have the rockerbody rub on the base also...?
            when i go to the store and wish to order the 8mm 3/8 top arp studs, shall i contact you or the store for these specifically since that is all i need? rather, since i already have the rockers.
            thanks
            cody
            • El_Diablo
              STFUniversity
              • 917
              your question has already been answered-
              and heres one place out of many to get them
              • rsisbetter
                • Mar 2006
                • 151
                http://store.summitracing.com/partde...0&autoview=sku
                but that doesnt make any sense, the rocker has to rest upon the stud, before the pushrod even comes into play. yes, the rocker is resting on the stud in my case, but in the absolute wrong place, it shouldnt rest on the body. and if it is there is somthing wrong, and lets say the rocker is "supposed" to rest on the base, for whatever reason, every valve would be open, because the rocker is sitting over an inch lower than it is supposed to. thus maxing the rockers job as to lift.
                • El_Diablo
                  STFUniversity
                  • 917
                  no, the rocker doesn't rest, it simply uses the stud as a pivot point, these aren't like the stock rockers... they rest on the pushrod and the valve stem tip
                  • rsisbetter
                    • Mar 2006
                    • 151
                    ok, cause the stock style what i was thinking of.
                    thanks
                    BTW: does anybody have the part number for the arp 8mm/3/8th's studs please?
                    thanks
                    • cleanz
                      • Oct 2005
                      • 20
                      Arp's part number is 134-7221 for the 2 piece pack. This will allow you to buy only 6.
                      Also you will not be able to use your current rockers on 8mm studs. They will be loose on the studs. You need to look into getting another set.
                      Brien
                      • rsisbetter
                        • Mar 2006
                        • 151
                        loose on stock rockers? or...?
                        • cleanz
                          • Oct 2005
                          • 20
                          You say your new roller rockers fit the lager studs you already have. If you go to a smaller stud the roller rockers will be too large to be able to use them.
                          • geoffinbc
                            • 5831
                            Brien
                            They are 3/8" on the top and work perfect.
                            • cleanz
                              • Oct 2005
                              • 20
                              Whoops. My mistake. I was half asleep and missed a line in the catalog.
