diagram of coolant flow on 3500
  • merlot566jka
    • Nov 2006
    • 570
    well im just waiting for my cam and reluctor wheel and i was doing some other small things untill they get here.
    one problem i have is i dont know where any of the stock 3500s coolant hoses go and come from. specificly i just need the basics, radiator in and out and heater core in and out. my car has no other provisions for coolant.
    any info would be great!
    2012 Chevy Sonic Turbo 6spd
    The water pump big inlet on the bottom comes from the bottom of the radiator. The coolant thermostat neck goes to top of radiator. Black hard pipe coming from top of water pump comes from heater core. The black hard pipe coming from lower intake manifold goes to heater core. And on mine there is a coolant reservoir that has 2 small lines going to top of radiator, and from the thermostat neck, and then a medium one going to the big hose that goes to the bottom of the radiator..
    • merlot566jka
      • Nov 2006
      • 570
      ok thanks! the fiero has the reservoir up front, and its just a overflow, so there is no need for all the extra stuff. all i have is a heater core and radiator
      • americasfuture2k
        • May 2008
        • 146
        is there picture diagrams of whats what and where it goes? that would help me understand a bit better.
        ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
        87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
        • 95SleeperAcheiva
          ArtofOlivia"PocketRocket"
          • Jun 2006
          • 694
          that black steel pipe that runs to heater core.... can i just omit that and get the top hole welded shut? Then weld shut the heater core hole in the LIM?
          I currently got it looped (no heater core), I wasn't sure if it part of the flow system or not.
            I had a pic at one time, no idea where it went. Not on my websites at least.
            You want to keep the heater core coolant lines connected at least. Superdave tried just blocking both off and kept getting air bubbles and overheating.
            Not sure if this helps any
