DIY Plenum Spacers for 3x00?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    Hope that stuff is not highly porous, if you receive a vacuum leak then you'll know 99% what it is.
    • IanSzgatti
      • Oct 2006
      • 519
      Originally posted by IanSzgatti View Post
      how is a mold going to be made???
      ....sorry, just wanna know
      • IsaacHayes
        Mr. Orange.
        • Apr 2006
        • 6030
        Well if you have nitrous and fuel nozzles installed in it then it will see gas vapors... And likely oil vapors just from normal use.
        • FallenZ24
          • Nov 2005
          • 178
          I'm not going to make a mold. If I was, I'd use styrofoam & clay. That way the mold can be broken off the part.
          Yeah, this stuff tools like wood but is very dense. It leaves a smooth finish when ground with a carbide bit.
          -Joseph
          • merlot566jka
            • Nov 2006
            • 570
            Originally posted by barrok69 View Post
            omg...
            are you trying to call me a dunce? happy hollidays buddy....
            El_Diablo:
            ive seen using paper mache and epoxy or maybe even polyester to make a bulk of material that was used for a carb spacer
            2012 Chevy Sonic Turbo 6spd
            • FallenZ24
              • Nov 2005
              • 178
              #21
              Just a little update. I worked on the spacers for a while Saturday until my buddy's porting tool took a shit. Hopefully tommorrow I'll go over to the shop and work on them some more. All that is left is to finish shaping the ports and trim off the excess material. Here's some pics as promised.
              I just traced the gasket onto the material.
              Using a hole saw, drill bit, and drill press I roughed out the ports and bolt holes.
              A little port shaping with a porting tool (die-grinder) and a carbide bit.
              After I shape ports to the correct size I will get some sand paper and smooth them out. That way they are nice and smooth and port matched to the gasket. I also plan on port matching the intakes.
              -Joseph
              • MidnightriderZ24
                • Jan 2005
                • 699
                #22
                let us know how it turns out! that looks like a good diy!
                [SIGPIC]
                12.268@117... 11's to come!
                  Live life 3.7mi at a time
                  • 4555
                  #23
                  If you have access to a router, then you could use a flush-cut bit in it and just trace the gasket with the bearing mounted on the end.
                  Looks good so far I'm curious to see how it seals.
                  • mfewtrail
                    ~600hp worth of 3.1's
                    • 170
                    #24
                    I'm curious to see how well that material will hold up to heat, oil, etc.
                    Matt F.
                    TGP 1/4 mile times
                    http://photobucket.com/albums/y33/mfewtrail/
                    1990 TGP Coupe VIN Database
