My Long Block Build is Complete!
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    #61
    The end results in the polished and chromed looking identical? Or similiar?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • barrok69
      • Apr 2006
      • 34
      #62
      To answer your question, I went with a custom cam, Intake lobe from the 1280 and the exhaust from the 1331
      216/240 278/289 .517/.568 113 ICL 114 LSA
      Hopefully a good monster for what I want.
      I was looking at that cam for my big boost motor build. Still haven't decided yet though.
      -=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
      14.99@91.33mph
        Live life 3.7mi at a time
        • 4555
        #63
        Did you click the link I gave you in post #59? They look chrome, but need a clearcoat to keep that appearance. Chrome is a lot more durable then polished aluminum as far a scratching etc (chrome is a heavy coating), but under the hood if you clear laquer the aluminum to resist stains and oxidation etc - it will last just as long. Laquer is usually found on OEM aluminum rims, and is quite durable.
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          #64
          Thanks for the tips!
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            #65
            They can be, but a good in person eye can see what it really is. Chrome is nice, but it (IMO) is the easy way out. I prefer the polish alloy look since you know it took & it just looks better.
              • 4555
              #66
              Well, this is 3x00 covers that are polished in my shop...
              They look even better up close. Since these, the process has been perfected and they come out even better. Here's what they looked like when started...
              and after the whire brush...
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                #67
                Cool. Jason Farnsworth is doing mine. $40 a valve cover
                  • 4555
                  #68
                  I saw the thread. $100 set is a good deal.
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    #69
                    Here you have it guys. This is what I paid for my Performance 3400 short block including the installing of WOT-Tech Street/strip heads and valvetrain with correct length moly pushrods.
                    One note on the quote is the Cam they had grinded by schneider. I sold that grind and went with a WOT-Tech 1357 Cam.
                    Be prepared to drop your Jaw. This doesn't include what It cost me to have the heads ported and the cost of the valvetrain. All they did was install and clearance the heads.
                    New Compression and Cubic Inch
                    Initial Spin Specs, Bobweight Card, and Final Spin
                    Sonic Check Specs
                    Complete 3400 RECEIPT part #1
                    Complete 3400 Receipt part #2
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      #70
                      You paid in cash? Are you a dope slinger? Who pays cash beyond 2000.00 let alone what you paid!?!?!
                      Oh yea, one last thing... Can I have a few G's? You evidently have money in the bank.
                      • IsaacHayes
                        Mr. Orange.
                        • Apr 2006
                        • 6030
                        #71
                        To chrome aluminum you need to plate it with nickel first. Usually copper, then nickel, then chrome. Don't know about the back side of the cover, if that is not smooth and prepped then it might flake which would be bad inside a motor. No idea how cast aluminum would take either. I'm guessing Ok if you got it smooth enough. Chrome will have a bit more bluer or darker tint to it than polished aluminum.
                        Just get some good high temp clear so it doesn't yellow and coat em nicely after polish.
                        • 1988GTU
                          LB62LHObbqftmfw
                          • Nov 2005
                          • 2475
                          #72
                          Cast takes in fine IF you can clean the pores good enough with the aforementioned steps. Depending on where you have it chromed it'll either have a blueish tint or blackish tint.
                          • blackbombshell95
                            Kaiō-ken X 10
                            • Jun 2004
                            • 1386
                            #73
                            Didn't you know that Cash is the only way to do business :P.
                            That shop takes Cash and Checks ONLY.
                              • 4555
                              #74
                              As in paychecks
                              • 1988GTU
                                LB62LHObbqftmfw
                                • Nov 2005
                                • 2475
                                #75
                                As in paychecks
                                lmao ... The machine shop I goto takes credit, checks, MO, limbs, & cash.
