So, a few of you might recall that i had built a 3400 to go into my sunbird over the spring/summer, and dropped in it back in august. And proceeded to have #3 rod bearing shred and lock the motor up, due to(i think) a warped rod i didn't know about. Puled it and replaced the motor with a stock 3400 for now.
Now i'm rebuilding and i need some assistance. I'm planning on getting the block bored .020 over(as long as that cleans the bores up) and i'm looking at pistons.
Does anyone have any suggestions as to what pistons i might use? This is going to be a N/A motor, *maybe* a small shot of nitrous down the road, but that's only a maybe. the only ones i've found thus far are these -
And the description says they're flat-tops. Now, i'm looking for a bit more compression than stock, but i know the 3.4 iron head pistons have a slight dish, and they give something like 13:1 compression. This is a DD so i want only about 10.5 or 11:1, MAX. these are shown for 3.4L up to 2005, which would be the 3400.... plans are if i cant find any stock pistons to give me a compression bump, to shave .020 off the tops of the pistons, and run 3.4 iron-head headgaskets.....
any suggestions?
any suggestions?
By the way the pistons that you listed were stock 3400 pistons and 3500 heads will drop your cr to around 8.8:1, not good for N/A performance.
