lx9 generator connections...wtf
  • merlot566jka
    • Nov 2006
    • 570
    05 chev malibu
    2012 Chevy Sonic Turbo 6spd
    • merlot566jka
      • Nov 2006
      • 570
      ok to update...terminal l is def for the dummy light. the 10ga red wire connects back to the same wire thats on the stud of the alt. so terminal f is only thing left to figure out what it does or needs.
      • merlot566jka
        • Nov 2006
        • 570
        Valeo TG11
        Charging System Description and Operation
        Generator
        The generator features the following major components:
        The delta stator
        The rectifier bridge
        The rotor with slip rings and brushes
        A conventional pulley
        Dual internal fans
        The regulator
        The pulley and the fan cool the slip ring and the frame.
        The generator features permanently lubricated bearings. Service should only include tightening of mount components. Otherwise, replace the generator as a complete unit.
        Regulator
        The voltage regulator controls the rotor field current in order to limit the system voltage. When the field current is on, the regulator switches the current on and off at a rate of 400 cycles per second in order to perform the following functions:
        Radio noise control
        Obtain the correct average current needed for proper system voltage control
        At high speeds, the on-time may be 10 percent with the off-time at 90 percent. At low speeds, the on-time may be 90 percent and the off-time 10 percent.
        Circuit Description
        The generator provides voltage to operate the vehicle's electrical system and to charge its battery. A magnetic field is created when current flows through the rotor. This field rotates as the rotor is driven by the engine, creating an AC voltage in the stator windings. The AC voltage is converted to DC by the rectifier bridge and is supplied to the electrical system at the battery terminal.
        When the engine is running, the generator turn-on signal is sent to the generator from the powertrain control module (PCM), turning on the regulator. The generator's voltage regulator controls current to the rotor, thereby controlling the output voltage. The rotor current is proportional to the electrical pulse width supplied by the regulator. When the engine is started, the regulator senses generator rotation by detecting AC voltage at the stator through an internal wire. Once the engine is running, the regulator varies the field current by controlling the pulse width. This regulates the generator output voltage for proper battery charging and electrical system operation. The generator F terminal is connected internally to the voltage regulator and externally to the PCM. When the voltage regulator detects a charging system problem, it grounds this circuit to signal the PCM that a problem exists. The PCM monitors the generator field duty cycle signal circuit.
        Charging System Indicator
        The IPC illuminates the charge indicator in the message center when the following occurs:
        • The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
        • The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage.
        • The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
        • The ignition is ON, with the engine OFF.
        from gmdealer world
        • merlot566jka
          • Nov 2006
          • 570
          Document ID# 1459957
          2005 Chevrolet Malibu
          Charging System Test
          Step
          Action
          Value(s)
          Yes
          No
          1
          Did you perform the Diagnostic System Check - Vehicle?
          Go to Step 2
          Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
          2
          Important: The battery must be above a 70 percent state of charge. Refer to Battery Charging .
          Did you perform the Battery Inspection Test?
          Go to Step 3
          Go to Battery Inspection/Test
          3
          Install a scan tool.
          Start the engine.
          With a scan tool, command the GEN-L Terminal OFF and ON.
          Observe the Ignition 1 Signal parameter.
          Does the voltage change with each command?
          Go to Step 4
          Go to Step 8
          4
          Turn ON the following accessories:
          - Headlights (high beams)
          - Air Conditioning (A/C) on Max
          - Blower fan (on high)
          - Heated seats (if equipped)
          With a scan tool, observe the Ignition 1 Signal parameter in the engine data list.
          Increase engine speed to 2,500 RPM.
          Is the voltage within the specified value?
          12-15.5 V
          Go to Step 5
          Go to Step 6
          5
          Turn OFF all accessories.
          Turn OFF the ignition.
          Caution: Make sure that the load is completely turned off before connecting or disconnecting a carbon pile load tester to the battery. Otherwise, sparking could ignite battery gasses which are extremely flammable and may explode violently.
          Connect a carbon pile tester to the vehicle.
          Important: When measuring generator output current, be sure the inductive probe encircles the generator output wire.
          Connect an inductive ammeter probe to the output circuit of the generator.
          Start the engine.
          With a scan tool, command the GEN-L Terminal ON.
          Adjust the carbon pile, as necessary, in order to obtain the maximum current output.
          Is the generator output greater than or equal to the load test value, as specified in Generator Usage ?
          Generator OK
          Go to Step 7
          6
          Is the voltage measured greater than the specified value?
          15.5 V
          Go to Step 12
          Go to Step 7
          7
          Leave the vehicle accessories ON or maintain load test value.
          Maintain engine speed at 2,500 RPM.
          Measure the voltage of the battery.
          Measure the voltage between the generator output terminal and the generator metal housing.
          Is the voltage measured at the generator within the specified value of the battery voltage?
          0.2 V
          Go to Step 14
          Go to Step 9
          8
          Turn ON the ignition, with the engine OFF.
          Disconnect the generator harness connector.
          Measure the voltage between the generator turn on signal circuit and ground.
          With a scan tool, command the GEN-L Terminal ON and OFF.
          Does the voltage measure greater than the first value ON and near the second value OFF?
          4.7 V
          0 V
          Go to Step 14
          Go to Step 11
          9
          Maintain the engine speed at 2,500 RPM and continue to operate the generator at the load test value.
          Measure the voltage drop from the battery negative terminal to the metal housing of the generator. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
          Is the voltage measured less than the specified value?
          0.5 V
          Go to Step 10
          Go to Step 15
          10
          Measure the voltage drop from the output terminal of the generator to the positive terminal on the battery. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
          0.2 V
          Go to Step 14
          Go to Step 16
          11
          Test the generator turn on signal circuit for a short or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
          Did you find and correct the condition?
          Go to Step 19
          Go to Step 13
          12
          Test the generator battery voltage sense circuit, if equipped, for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
          Go to Step 19
          Go to Step 14
          13
          Inspect for poor connections at the harness connector of the powertrain control module (PCM). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
          Go to Step 19
          Go to Step 17
          14
          Inspect for poor connections at the generator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
          Go to Step 19
          Go to Step 18
          15
          Repair the high resistance or open in the ground circuit of the generator. Refer to Wiring Repairs in Wiring Systems.
          Did you complete the repair?
          Go to Step 19
          16
          Repair the high resistance or open in the generator output circuit. Refer to Wiring Repairs in Wiring Systems.
          Go to Step 19
          17
          Important:: The replacement PCM must be programmed.
          Replace the PCM. Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
          Did you complete the replacement?
          Go to Step 19
          18
          Replace the generator. Refer to Generator Replacement .
          Go to Step 19
          19
          Operate the vehicle in order to verify the repair.
          Did you correct the condition?
          Generator OK
          Go to Step 2
          • merlot566jka
            • Nov 2006
            • 570
            needs 5 volts to turn the gen on at term L. then term f is not used and the gen to guage will just be any b+ signal
            i just need a 5 volt ref, like say the tps or map's 5v ref signals. as lont as the ecm is on the gen will be on....
              #21
              Taping into a 5v ref that goes to a sensor might be a bad idea. You can go to radio shack and get a 7805 5v regulator and hook that up to send 5v to it instead.... Just set it up to power up on key on...
              • merlot566jka
                • Nov 2006
                • 570
                #22
                i taped into the map, it works. but ive got some map problems now...lol. there are other 5v refernces on my ecm that rarent used anywhere, ill try those in a bit
                  Live life 3.7mi at a time
                  • 4555
                  #23
                  I say follow Isaac's advice. 5v regulator to ignition on and alt switch.
                  • merlot566jka
                    • Nov 2006
                    • 570
                    #24
                    Welcome to RadioShack's official website. Search and shop for electronics, gaming devices, powerbanks, audio products and business traveling gear.
                    do i need any buffer or anythign else for this circut? 12v, ground and it puts out 5v?
                      #25
                      Not required, but perhaps a diode in front of it would help protect it from any reverse spikes going through the car's 12v system. A capacitor between 12v in and ground might help dampen any swings in voltage too. Not sure if swings in voltage would be too fast for the regulator to react to or not.
                      • 3100 MPFI
                        • 1522
                        #26
                        I check my 1990 STE 3.1 today, and it has the big red wire. It goes to the starter under a seperate fusible element. Basically, my alt has 2 wires going to the starter (one from the plug, and the other from the stud).
                        Taylor
                        1998 Lincoln Mark VIII
