Multec 2 injectors
  • loner666
    • Oct 2006
    • 435
    Multec 2 injectors
    Anyone know where to get 36lbs or 42lbs Multec2 injectors? my 36lbs Multec1s are causing small vaccum leaks so im going to upgrade to the newer ones since they are alittle longer in hopes of it fixing the problem.
    any help will be great
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
  • geldartb
    The Situation
    • May 2004
    • 1994
    http://cgi.ebay.com/ebaymotors/GM-3-...spagenameZWD1V
    i got some of these from him awhile ago.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • loner666
      • Oct 2006
      • 435
      those have the same plug as the 03 3400 impalas right? i have the harness for the plugs as longs as they are the same im good
      Daily Driver
      • zofo61
        Banned
        • Oct 2005
        • 436
        I dont think they are the same plug as the 3400...they look Bosche type to me....I have a set from a GTP and they look the same at 36#ers as well. They need the adapters from zzp to hook up to a 3400 harness. I have a set of six for a lot less than the eBay link above if you are interested?
        • geldartb
          The Situation
          • May 2004
          • 1994
          you have to wire new plugs on, which is what im doing for mine.
          if your at the yard and looking for new plug i found the dodge neon and chrysler version have the same plugs, along with the 03 era crown vics.
          99 Grand Am GT
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            I didn't think Delphi made a 36 or 42# Multec 2 long type injector.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
            • loner666
              • Oct 2006
              • 435
              like i said i have the 03 3400 plugs but if those wont work then ill have to find another set or try sealing my Multec1s
              Daily Driver
              • geldartb
                The Situation
                • May 2004
                • 1994
                just go get the plugs from a yard near you. i did it awhile back to run the 00+ injectors, and now im doing it for the gtp injectors.
                99 Grand Am GT
                • loner666
                  • Oct 2006
                  • 435
                  ok. Ill check out the yard next time im there. Not sure if they have any tho. What years do i need to look for?
                  Daily Driver
                  • geldartb
                    The Situation
                    • May 2004
                    • 1994
                    damn you gotta ask the hard questions.
                    i found them on the 03 era crown vic's the one i grabbed them off waws an old cop car but they should be the same on the normal ones.
                    for the dodge check the engines but it was the neon and what ever the other version of that is called with the 2.0 and 2.4.
                    ill check tomorrow and get you some specific cars that have them.
                    if you want i can grab a bunch it shouldnt cost more than a couple bucks to ship. but they wont cost me anything to get
                    99 Grand Am GT
                    • loner666
                      • Oct 2006
                      • 435
                      that would help too if you could grab me some
                      Daily Driver
                      • geldartb
                        The Situation
                        • May 2004
                        • 1994
                        ok ill see what i can dig up.
                        99 Grand Am GT
                        • Berettaspeed
                          • Apr 2004
                          • 109
                          i think most GMs after 00' has the thin style injectors. just get another harness for multecIs so you can use anything you find. the multecIs are shorter than the pencil ones. i would get 3800 SC injectors from GTP guys. i got 6 of them for 45 bucks. they upgrade them and get rid of them for cheap.
                          89 BerettaGT 3400 5spd
                          60' 2.106 street tires
                          Best ET 14.313@95.37 N/A
                          Now Boosted
                          14s@109 (poor tune still rich, poor driving skills, poor owner)
                          • loner666
                            • Oct 2006
                            • 435
                            arent the GTP connects different tho? like the "key" setup in them?
                            either way i think i got the injector leaks figured out for now but we shall see
                            Daily Driver
