tce reluctor wheel kit...checking timing??
  • merlot566jka
    • Nov 2006
    • 570
    how can i verify that its installed right? i want to check my base timing to see if i have it (it being the timing of the cps to the reluctor wheel) set right. can i use a timing light? im sure id have to make a pointer and mark the wheel some how. i know theres notches that are labled, but like i said, things changed on my install.
    i just want to verify that '0' degrees is where my zero is. i know fieros are a little different and my brackets made for the need to trim the cps holder.
    can it be done?
    2012 Chevy Sonic Turbo 6spd
    can it be done?
    I don't think so... with our computers the delivered spark timing is constantly variable based on RPM, engine temp, intake air temp and other factors that would make using a timing light virtually impossible.
    If it's running it's close enough...
    • merlot566jka
      • Nov 2006
      • 570
      damn
      • SHOoff
        • Jul 2005
        • 356
        Won't the ICM fire at 0* if it's disconnected from the ECU?
        97 Cavalier RS
        3400, Isuzu MK7
          I believe so, i wanted to check that a while back but never got the chance.
          • merlot566jka
            • Nov 2006
            • 570
            how?
            • CNCguy
              Bisong eater :P
              • 1017
              how?
              I know that you don't need the info right now but here it is for your next engine. Since the timing on a stock DIS system cannot be changed, GM did not put any timing marks on these engines.
              To check timing you will need to do the following: (easier to do when building the engine)
              1) Accurately find TDC for cylinder #1
              2) Engrave timing marks on the dampener (allow for pointer location and belt routing)
              3) Make a rigid pointer that points to the 0 timing mark
              4) Disconnect the EST wire (IIRC) and check timing with engine running
              When using the TCE external trigger, the timing should be within 1 degree of stock timing when it is set to 0. I had considered making some timing pointers but decided not to because of the many variables from vehicle to vehicle.
              MinusOne - 3100 - 4T60E
              '79 MGB - LZ9 - T5
              http://www.tcemotorsports.com
              • merlot566jka
                • Nov 2006
                • 570
                thats exactly what i thought!
                thanks so much
