3500 fiero failure
  • merlot566jka
    • Nov 2006
    • 570
    3500 fiero failure
    dunno what it was yet, ill find out in the morning....
    its making a lot of noise on cyl 2 4 6 side. sounds like a rocker arm smashing into the intake port. gets louder with rpm. oil pressure is around 65-70 psi hot.
    any guesses? ill know about 8 am tomorrow. im hoping i didnt drop a valve or something that would ruin the head, cyl or pistons
    2012 Chevy Sonic Turbo 6spd
    pull the valve cover and see if you broke a rocker stud...
      Live life 3.7mi at a time
      • 4555
      Nooooo. WTF? Hope it's something small.
      My turbo didn't last long, but it was a stupid mistake on my part. Hope that it's not as bad as expected. Hate it when a lot of work goes into a failure
      • merlot566jka
        • Nov 2006
        • 570
        im sure its nothing extreme. ill know in the morn.
        im thinking its a rocker arm or maybe a valve.
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          Collapsed lifters with bent pushrods with the added hint of smashed valves, MAYBE. No other noises?
          • 3100 MPFI
            • 1522
            I know a couple of times now, I have had a rocker come loose. I know one of the times had to do with my sister-in-law, the other time, I think it just was not seated right and worked loose. The second one, it was fine when I started it, but 2 days later was making noise.
            Taylor
            1998 Lincoln Mark VIII
            • merlot566jka
              • Nov 2006
              • 570
              hmm, maybe thats it. i had to take my brother to work, so ill be out to my car in just a few mins...wish me luck
              • Joseph Upson
                Where the rocker arm bolts torqued with a torque wrench or guestimated by feel? They shouldn't come loose if torqued properly.
                • merlot566jka
                  • Nov 2006
                  • 570
                  rocker arms were fine. oil smelled like fuel. it was knocking on the botom end. i changed the oil (it flowed like water when the oil was 40*!!) and threw a rod on the way home. its dead. time to see if all pro used auto parts lives up to thier 3 year warranty.
                  the engine sounds like a coffee cann full of ball bearing in a paint shaker. its fucked.
                  and not to mention i have $97 to my name. im so bummed. im gonna go take a shower and go to bed. see you guys later
                  • pontiacdohc@gmail.com
                    Pontiac DOHC
                    • Feb 2006
                    • 181
                    that blows if that parts store dont give a u new motor throw a brick threw window!
                    1997 Chevrolet Camaro 30th Anniversary 5Speed.
                    3800 V6 (i know its not a 60degree)
                    stock for now
                    1993 Special Edtion/GTP
                    3.4 DOHC V6 LQ1 SOLD!
                    CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
                    180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
                    VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
                    • merlot566jka
                      • Nov 2006
                      • 570
                      they are 2000 miles away....i cant throw that far
                        Shit. I hope they fix you up.
                          • 4555
                          Not from me
                          I wonder what failed? Fuel in your oil, hmmm...
                          • merlot566jka
                            • Nov 2006
                            • 570
                            it was running rich as hell....but im thinking leaking injectors? hell i dont know. i wont know for a while.
                            good news is that im getting a trailblazer this weekend so i can make it to work n back. only 61K miles and $9400 leather 4wd, loaded. im putting the fiero in the driveway till i get another 3500. i doubt allpro is going to live up to thier guarentee after what i went through with the cracked intakes. but im going to push em.
                            im going to take my time on this engine. maybe a wild cam? supercharger? turbo?
                            the entire ride home from the shop the oil pressure was around 45 and the coolant temp was around 225....funny stuff.
                            • nfswift
                              • Aug 2007
                              • 58
                              Mine came from the same place so I guess we'll see what their ratio of engines to grenades is soon enough!
