Technical Theory : Plenum Design
  • EspanolaGuitarista
    Visionary
    • Feb 2004
    • 254
    #91
    Thanks for the tip..didn't think about adding a cowl by itself. So 12 in. huh? So if I made a top half then I wouldn't need to mess with the egr setup? So 12 inches above that. That actaully seems very doable. Then a cowl to boot. Hmmm. By Goerge mate that awfully keen! :P
      • 9191
      #92
      The EGR is on the top half, so yeah... you would have to mess with it.
      • CNCguy
        Bisong eater :P
        • 1017
        #93
        Slowly making progress on my UIM. It still needs the end cap made and the final welding.
        Marc
        MinusOne - 3100 - 4T60E
        '79 MGB - LZ9 - T5
        http://www.tcemotorsports.com
        • 1QUICKHATCH
          • 387
          #94
          sweet! is that an LS1 tb?
          14.96@91.47 in the 1/4
          9.63@74.36 in the 1/8th
          • CNCguy
            Bisong eater :P
            • 1017
            #95
            The TB is from a 5.3l Chevy truck... 75mm.
            '79 MGB - LZ9 - T5
            • v6h.o.
              • 1418
              #96
              oh is that ever looking great Marc! congrats! very cool.
              Colin
              • CNCguy
                Bisong eater :P
                • 1017
                #97
                Thanks Colin... Im hoping it improves performance as much as it does the looks. I still need to port the heads, add LS1 springs, get a cam and make the billet valve covers. Have not decided on whather to rebuild the short block as it has 52k on it. Its a slow process since I dont have alot of money/time to put in it.
                '79 MGB - LZ9 - T5
                • v6h.o.
                  • 1418
                  #98
                  yeah but thats the best way to do things Marc, minimal investment + done the right way = excellent results!
                  Colin
                  • intlcutlass
                    • Jul 2004
                    • 2
                    #99
                    You might be able to use some data from this....
                    http://www.fiero.nl/forum/Forum2/HTML/047158.html
                    My guess is that you new design would yeild you 5-7 Hp...
                    Thats just a guess.
                    Good luck
                    • 93vinx
                      • 154
                      #100
                      that tb looks like it would bolt up to a stock 3.4 96 plenum, any one else? what do you think cnc guy?
                      vrrrooooooooooooooooom i need new exhaust
                      • CNCguy
                        Bisong eater :P
                        • 1017
                        #101
                        You could make an adapter to use it but it would be a waste of time as the TB opening on the 3400 UIM cannot be opened up to 75mm. Also the inlet area just behind the TB flange isnt very large either.
                        I dont know what effect this manifold will have but it should flow more than the stock one. I am sure of one thing, the modded 3400 should have considerably more power than the stock 3100 thats in it now.
                        Marc
                        '79 MGB - LZ9 - T5
                        • v6h.o.
                          • 1418
                          #102
                          Marc
                          i think he was refering to his 3.4L DOHC plenum which stock they are 64mm or are they larger on the 96's? i know 92-95ish is 64mm stock. (i have a 3.4L DOHC t/b butterfly in an over bored 2.3L throttle body housing :P)
                          Colin
                          • 93vinx
                            • 154
                            #103
                            i was referrring to the dohc, wil it bolt up? 75 sounds like a nice middle range number not to big or too small, i wonder on the availablity,
                            • CNCguy
                              Bisong eater :P
                              • 1017
                              #104
                              I misundertood your previous post.. lost I guess. As for whether it would fit, I have no idea as I have never owned a 3.4 dohc. Measurements could be taken from a manifold to see if it could be opened up that far and if the hole pattern is different, an adapter could be made.
                              I got the 75mm TB with IAC & TPS came from ebay for $25 & 10 shipping.
                              '79 MGB - LZ9 - T5
                              • 93vinx
                                • 154
                                #105
                                can you measure the bolt holes for me?that is the spaces between them
