starter question
  • neo71665
    its this big
    • Oct 2005
    • 361
    starter question
    Will a V8 starter fit on the side of a RWD 2.8-3.4? I just got done putting a factory replacement on this damn 4x4 and having to remove almost the entire front end to get to it next time I wanna put a gear reduction one on it if theres one that fits.
    87 3.4 4x4 blazer
  • Mr_Efficiency
    • Jan 2008
    • 197
    I'm not sure about the V8 starter but I know a lot of guys are using the 3X00 starters cause they are bigger than the older ones.
    Mr_Efficiency
    90 Grand prix - Lawn ornament
    Black, 3.1, 5 speed
    Future holds: Striped and then scrap yard
    97 Cavalier - Stock car
    Red/Black, 2.2 OHV, 5 speed, fully tubed bumper to bumper, 6 point cage with halo, fuel cell, race seat, 5 pt harness.... a race car
    Future holds: Just more trophies
    New project on the way: 88 S10 reg cab, short box, 5 speed.
    Future holds: Built 2.8 hybrid, Stealthy flat black, a drop until i have no more ugly wheel gap
    • MY91GT(Z)
      • Sep 2006
      • 387
      their not bigger they smaller and lighter and give more power when starting for faster starts
      • neo71665
        its this big
        • Oct 2005
        • 361
        Yeah but its on FWD which my blazer is not and I'm pretty sure FWD will not swap out to RWD so back to my question please. Does anybody know of a smaller gear reduction for a 2.8/3.4 or will a V8 starter work?
        87 3.4 4x4 blazer
        • latemodelnewbee
          • Jun 2007
          • 227
          have you checked a late model F body with a 3.4L, I think they stoped the 60 degree in 98 in the f body. They should have and smaller gear reduction starter and its a RWD set-up
          68 El camino 454 speed muncie 3.90 posi 12 bolt,
          80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
          60 Impala 2 door hardtop L79-327 T56 4.11 posi.
          83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
          91 Z34 now has a hm284. and belly pan in the works
            • 9190
            The last 60V6 in an FBody was 95.
            • latemodelnewbee
              • Jun 2007
              • 227
              I thought 98 is when they went to 3800 but anyways a 95 should still have a better starter
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                Nope the Camaro starter is the same as the S-10. It was the same from the start to the end of production.
                I don't think a V8 starter will work out of the box but it may be able to be modified to work. I don't think anyone has the answer for sure but you might want to go to the parts store and ask to see a stock 2.8L starter Vs A V8 starter. If they can interchange then you know a gear reduction starter will work.
                • latemodelnewbee
                  • Jun 2007
                  • 227
                  well damn, just an idea.
                  • neo71665
                    its this big
                    • Oct 2005
                    • 361
                    Well I guess I'll have to look at the one in the drag truck when the motor gets pulled and see. I was hoping somebody would know.
                    87 3.4 4x4 blazer
                    • neo71665
                      its this big
                      • Oct 2005
                      • 361
                      I know this is an old thread but since its mine blah.
                      I found this over at fullthrottle and it looks promising. If anybody cares
                      87 3.4 4x4 blazer
