3100 headers
  • Jbrogan
    • Oct 2006
    • 203
    3100 headers
    i want to buy S&S headers and put them on my beretta. but i was wodering tif the were goin to fit okay. i know they will bolt up and fit but i didnt know if the rear header would hit the body or anything like that.
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
  • geldartb
    The Situation
    • May 2004
    • 1994
    the rear wont fit youll have to modify it. search for a guy named 3400-95-modified, he modified a set to fit.
    two solution i know of are cut the firewall and modify the rear header.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      yeah u gotta modify the rear pipes, they need to bend down more. i got a set for mine, but havnt even taken them outside lol
        Yeah I got pics posted on Bstuff... here they are...
        Its not EASY to do.
        Here are some pics of the modifications I had to do to the S&S headers to get them to fit my car... Also pictured is Erics unmolested set... which will soon receive the same treatment.
        A few notes of things I did was cut all three tubes at the back flange and bent the main header down further to give it a sharper angle, then shortened and angled the last collector in the opposite direction so it wasn't aiming so far down. And lastly re-aligned the cross over pipe again.
        Completed header
        Last collector cut and weld.
        Cross over hacks, It could have been done it one cut on each side but since I didn't have both on the same motor it took me two or three shots.
        Bottom of rear down tubes.
        Angle of mine
        Comparison to unmodified... the rear flange does angle it a little more too since its not flat.
        Collector comparison
        collector flatness comparison.
        I have no definite measurements yet, I plan on bolting it to the motor and getting a comparison from stock S&S and my set so I at least know the difference in angle between the two sets.
          • 9186
          Time to bring up my imfamous picture, taken back in... 2004?? when the S&S headers were first introduced (I was one of the first people to recieve a set). Anyway, here is a comparison shot showing the different angles between a stock Beretta downpipe and the S&S headers. Enjoy!
          • Jbrogan
            • Oct 2006
            • 203
            what if i just get a set of 3400 exhaust manifolds and port them out, will that help. also are the 3100 and 3400 exhaust manifolds the same?
            1996 Beretta
            3100 SFI TURBO
              I like my pic better it compares a working set of S&S headers and the stock S&S header. Yes you were my inspiration. LOL
              • Jbrogan
                • Oct 2006
                • 203
                What about these?????
                1996 Beretta
                3100 SFI TURBO
                • andrew383
                  • Nov 2007
                  • 70
                  i just looked on pacesetters site and it says there a fit for the 3100/3400
                  sigpic03' 3100 slp cat back-custom fwi-gmpp trailing arms-mrz udp-aeroforce
                  • MY91GT(Z)
                    • Sep 2006
                    • 387
                    havent heard to many good things bout pacesetter headers especially on gp forums, i would think s&s is better quality from what ive seen on the boards
                    • Alxsmt
                      that one guy
                      • Feb 2007
                      • 725
                      one of my freinds got pacesetters on his v6 4runner. it sounded like an old vw bus lol
                        Pacesetters have more connections, and still won't clear like the S&S
                          There are no headers for a Beretta, except for the ones I modify and after shanes set, I'm DONE doing that.
                          Thats why I posted pics of what you need to do to accomplish what I did.
                          Bolted to my test motor I had to add 20* to the angle downward, I started with around 40 and ended with 59 to get them to match my set.
                            We are going to lock you in a basement and make you modify headers and give you 50cents a day and a slice of bread Jon.
                            • MY91GT(Z)
                              • Sep 2006
                              • 387
                              Thats just krewl ^^^ lol
                              thanx to jon and the other guy some of us will have headers for these cars and i bugged jon for awhile and i know ill be getting a quality job from himand have no worries and when i get my car runnin ill let him see how fun it is to have a 5spd w/ similar setup to him w/o the cam, and im pretty sure he'll have a tired leg playin w/ stg3 clutch
