My "Little" Project
  • grimmcs
    • Jan 2006
    • 135
    My "Little" Project
    I forgot to post this over here. My plan is to turn my 3.1 into a turbo hybrid 3.1/3100. So far so good. Ive got a lot of parts just waiting to get put on. So here is some pics to get you caught up on my project...
    What it started with...
    Had an issue with a rust hole, failed inspection, which got me here...
    I figured "Why the hell not?"...
    Soon this...
    Turned into this...
    Got it on the stand...
    Took all the goodies out...
    And today I did this...
    More info and pics here------->LINK
  • MidnightriderZ24
    • Jan 2005
    • 699
    looks like its coming along nicely man!
    [SIGPIC]
    12.268@117... 11's to come!
    • Rhedalert
      Dr. Feelgood
      • 1574
      hot stuff man, hot stuff!!! I envy your powertrain coming out the top!
      Brian
      3400 SFI V6, 4T60e
      • El_Diablo
        STFUniversity
        • 917
        dont we all.... im dreading the day i pull the fiero shell off of the cradle, that and the malibu, think the bu might be a lil worse, lol
        • grimmcs
          • Jan 2006
          • 135
          Yeah, It was really nice being able to pull the engine/tranny out the top. Thanks for the complements. I think I can almost see the light at the end of the tunnel...
          Just thought you guys would want to see what I am throwing under the hood with all the other goodies...
            Live life 3.7mi at a time
            • 4555
            Where did you get that
              LOL sure looks familiar!
              I hear you about rust. Mine looks great on the outside like your car but the rockers aren't doing so well... Same color about as your car too! lol
              • grimmcs
                • Jan 2006
                • 135
                Got sent home early from work today("Oh no, hes near overtime!!!! Send him home!!!) so I figured I would clean the mess, under the cylinders, that I made while honing. The mess first smeared and all the shavings found their way into the texture on the underside of the engine. After about 2 hours of cleaning I cant tell if the shavings are still there or if I just cleaned it that well.
                I dont really want to take the chance of the shavings still being there, and slowly ruining my engine, so I now have to find a place around me that will hot tank my block...Which sucks because I wanted to have the engine mostly put together by Monday Not anywhere ready to put it back in...Just want to get some stuff put on/in the engine.
                And me putting in my posi by the time Im done isnt looking good anymore. These things are adding up and the posi might have to wait
                • grimmcs
                  • Jan 2006
                  • 135
                  You guys think that this will work.....
                  There is still some work to be done. Im going to clean it up a bit, match the TB opening to match the TB, and grind off the EGR port. But I wanted to throw it together to see it.
                  To answer a few questions before you ask them...
                  Yes, the TB dosent cover that opening at the top of the neck of the UIM. I have a plate that seals that opening, but the bolts I have are not long enough to hold the TB and plate to the UIM. So there is no problem there.
                  Yes, that is the stock TB linkage adapted to a later year shaft. A buddy of mine "mushroomed" the rod where it stuck threw the linkage. There was a tiny bit of side-to-side play, so he covered the end in JB Weld. It wouldnt have gone anywhere anyways...he just wanted to use some JB Weld.
                  • DEI37
                    • Jan 2004
                    • 516
                    JB Weld...nothing wrong with that! Looks like a lot of fun, though...that's for sure.
                    • grimmcs
                      • Jan 2006
                      • 135
                      I found a shop that builds race engines that can hot tank my engine and replace my cam bearings for $60. If I want them to replace my freeze plugs it will be a few more dollars. But, I think thats a good price and its right on my way to school
                      I do have a question about the freeze plugs. I know I have 1 on each side and 3 in the back of the engine, and these are 34.3mm, correct? On the website that Im looking at has 2 sizes though...7/8" and 34.3mm. Are there plugs that I am forgetting?
                      In this pic, where the starter bolts up, is that a little freeze plug?
                      • El_Diablo
                        STFUniversity
                        • 917
                        whats the shop your having do the work? i need to find one around here to do some for me....
                        • GM Gimp
                          2007ImpalaMark
                          • Mar 2008
                          • 1
                          Hello, I'm new to this forum but have built numerous V8 engines for drag racing. If you have the block hot-tanked you should also wash it thoroughly with soap and water. Hot-tanks sometimes leave residue that comes from numerous cleanings in the same tank. The soap and water works better than anything else for removing grit from the cyinder walls. Of course immediately spray the cylinders with WD40 and use compressed air to get the water out of all the holes and crevices. Make double sure the holes for the main cap bolts are dry. I've actually seen cracked blocks from the main bolts compressing water.
                          • grimmcs
                            • Jan 2006
                            • 135
                            The place I found is called Dunk Competition Engines. They are right off of Rt. 8, heading tward Butler.
                              That TB is on upside down you know that right?
                              nevermind I think I see why you did that, but wouldn't it be easier to try and change the way the TB cable is, but whatever works I guess.
                              And I'm guessing thats 3400 heads and lower intake?
