let me get this straight....
  • rsisbetter
    • Mar 2006
    • 151
    SO, lets say one was to ground down the 3500 crank/rod journals to 1.99x such as that which is the same as the 3400, does that mean you could then also use sbc rods in 3500?! or is the 3500/3400 have different rod lengths?
    • 9190
    3400 rod length is 5.7", whereas 3500 rod length is 5.9". BUT, it depends on which pistons you use as well, as the pin height also affects where the piston will sit at TDC.
    Seems like it would be more cost effective in the end to just custom order some rods instead of spending all the $$ for the grinding of the crank, grinding of the rods (big end has to be narrowed), and then possibly different pistons as well.
    • rsisbetter
      • Mar 2006
      • 151
      k, just making sure, cause sbc rods are going to be wayyy cheaper than a custom set, and offset the cost.
      thanks
      • torq455
        If I only had money!!!
        • 1615
        does that mean i could put the rods/pistons from the 3500 directly into the 3400? i know the CR will increase due to the difference in combustion cc's.
        Andy
        fastest 1/8: 10.19@ 67.17
        fastest 1/4: 16.16@ 82.70
          you'd have to bore it into the water jackets....
          • rsisbetter
            • Mar 2006
            • 151
            that wouldnt hurt anything, good for 500hp easily!!
            • torq455
              • 1615
              ahh duh. bigger bore. damn, i shoud have remembered that! ok so i'll fill the jackets.
              Andy
