3400 temp
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    3400 temp
    ok i prettymuch dont know anything about engine temps, all my cars just have a gauge with no numbers so i dont know whats what. im looking into aftermarket digital water temp gauges to keep a better eye on my new engines temp.
    so what temp range is what?
    cold:
    running:
    hot:
    fried:
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Cold will be whatever the outside temp is.
    Running should be 200*F
    Hot is 220*F to 230*F
    Fried is anything over 230*F.
    keep in mind some iron head motors are well known for surviving temps up to 280*F but only for a short time. Aluminum head motors should never venture over 230*F for any length of time. Especially a Dodge 4cylinder LOL
    • geldartb
      The Situation
      • May 2004
      • 1994
      my 99 grand am hangs around 200 once its warmed up.
      in the winter with the 180 t stat it would hang around 180, turn the heat on anything above 2 and it temp drops, but ive heard with the grand am's even completely stock cars it bleeds off rather quickly.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        Fan kick on for my 3100 is 227F. Running is between 170-200, depending if you are moving, how cold it is outside, or if you are stopped in traffic. In winter it barely will get up to 170. Usually is around 160 in winter.
        Mine went up to almost the red once when the trans cooler was leaking inside the radiator, which put trans oil in the coolant which didn't help cooling. On my gauge 1/2 is 200, and a hair over is 227, lol. So the temp rises drastically the higher the gauge goes. 1/4 is 180 IIRC.
        • Alxsmt
          that one guy
          • Feb 2007
          • 725
          ok cool, thanks guys
