How Can I Make My 2.8 V-6 More Powerful
  • Olympia
    Ain't family life grand
    • Feb 2008
    • 4
    I have a 2.8 v-6 in my 85 cherokee. People have told me that I should either put a 3.4 in there, or get a vortec 4.3, or just sell it and get a cherokee with 4.0l straight six. Thats all well and good, but I like my jeep, and I don't want to do an engine swap.
    So my question is this: HOW CAN I MAKE MY 2.8 MORE POWERFUL?
  • MY91GT(Z)
    • Sep 2006
    • 387
    u can do a 3400 top end swap that would make it breath alot better and do a 2.5" exhaust w/ sr8 through flow muffler, udp and home depot homemade cai that right there would cost u bout 5-600 if u do it urself
    • Olympia
      • Feb 2008
      • 4
      First off, I appreciate your input, secondly... what is a 3400 top end? I understand the exhaust, but what did you mean after that
        The 2.8 is carb though right? So you'd have to convert to DIS.
        3400 is a 3.4l aluminum head FWD engine that makes 185hp. Top end would be heads on up.
        UDP = underdrive pulley
        CAI = cold air intake
        • Olympia
          • Feb 2008
          • 4
          Yah my 2.8 is a two barrel carb. What does DIS mean? Is that fuel injection, or throttle body? And how hard would it be to do a top end swap?
            3400 is fuel injected, 6 injectors, and DIS is distributor-less ignition system. You'd need an external crank trigger too cause your crank doesn't have one since it uses a distributor.
            Probably the best route is to get a 3.4 RWD camaro motor, and swap on 3400 top end and pistons on that, then run it with some computer, either the older OBDI computers or a stand alone. That would give you good power.
            It's not going to be easy or simple stuff to get more power. You'll have to do some work.
            • 1meanz
              • Nov 2007
              • 197
              its almost impossible to make GOOD power on a carbed 2.8, but with a 3400 top end you could make good power because of how good it breaths. thats deffinatly the way i would go
              • JMo60
                • Oct 2005
                • 300
                turbo
                94 Grand Prix
                • montess408
                  • May 2006
                  • 391
                  just to keep it simple and not go overbord i would just get headers and good exhaust system with a cam and edelbrock intake and a 390 4bbl holley
                  it will give you a bit more power but nothing compare to the gen 3 stuff
                  • ssdurango
                    • Dec 2004
                    • 170
                    I've got an eldelbrock intake for a carb if your interested
                      Yet nobody asks the 3 most important questions..
                      1. How much power are you looking to make?
                      2. Is this a daily driver, also what do you do with it.. towing anything?
                      3. How much money are you willing to spend?
                      • 1meanz
                        • Nov 2007
                        • 197
                        yea! what dave said! lol. also, how handy are you at working on engines? and what kinda tools do you have? other very important ?'s
                        • Olympia
                          • Feb 2008
                          • 4
                          well, my goal for my jeep is to make it able to take trails and almost anything that I can throw at it, besides heavy duty rock crawling. and I am able to do most anything under the hood, as long as i have my in laws help. I think for now I'm gonna put exhuast, headers (since this is a 2.8 in a cherokee, where can I find some headers that I wont have to modify anything to install), I'll also do a bigger carberator and heads and cam.
                          • montess408
                            • May 2006
                            • 391
                            your best bet on the heads is to get a set of h.o heads or 3.4 and get them ported
                            becaus there is not aftermarket heads for the iron heads 2.8 and the aluminum heads dont fit a carb setup
                              If youre handy with a TIG welder then you could easially fab up a carb flange ontop of a 3400 UIM, plug the injector holes.. get a little crafty with the dizzy and then have a really good flowing top end.
                              The Gen3 heads flow almost twice as much as the iron heads, if you want power that's about the only way to get it. A larger cam will only compliment the heads more.. and headers would be icing on the cake.
