EGR adapter plate sources?
  • TheDirtyBen
    • Mar 2004
    • 130
    is anyone making an egr adapter plate affordably? i want to do the 3400 swap, but i have the tri-solenoid EGR and would prefer to keep it, than do a PCM and harness swap. and no, i don't want to just block off the port.
    Who is making them, if anybody, and what kinda price are we talking?
    BTW, this is for a 94 Olds Achieva w/3100.
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
    • 9186
    Goto beretta.net and do a search. I know there is at least 1 person if not 2 that are making adapter plates.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      What year 3400 are you going to use?
      I can make them
      If we (Lloyd and I) get enought potential buyers we are going to make a bunch of them. There is more to it than just the plate. You have to make a special fitting in order for the old hose to attach to the new manifold. So if you wanted it done you would have to send me your old parts and I also need the hose for the new manifold.
      • TheDirtyBen
        • Mar 2004
        • 130
        i am perspectively looking for a post 2000 3400. basically, right now i am trying to get a rough guesstimate on price for the plate. if possible, i need little or no down time on the car. it's all i have for transportation. i'm a Transmission mechanic and work in an auto shop environment. I will be doing the swap in a matter of hours. so, i'm working on all of the pre-planning in advance. heh, i don't even have the 3400 yet.
        K&N cylinder filter
        Front STB
        • Joes95gagt
          • Mar 2004
          • 58
          If you get a UIM from a 99 3400 you won't need to get an adapter.
          To Many Mods To List, Check It Out At
          Joe\'s 95 GA GT
          3100 Best ET : 15.389 @ 90.48Mph
          3400 Best ET : TBD
          My Cardomain Site
            • 9186
            Yes you do. EGRs changed in 96, so any work done on a 94-95 will need an adapter.
            • 95BlackRoseZ26
              • 32
              I bought an adapter for my 2002 upper manifold from McGavinZ26 on beretta.net. My 95 egr mounted up no problem, using the original pipe. I just needed the gaskets for the 95 egr and the gasket for the 02 egr also, along with some longer screws to accomodate the adapter. I paid $60 plus shipping.
              • pantera
                • Nov 2003
                • 6
                Yea your pipe bolted up because you have a 3100. But a 3.1L/2.8L needs a special fitting for the pipe off the 3.1 EGR system to bolt to the 3400 manifold. So far I do not think that anyone has done this except Geoff and I
                • geoffinbc
                  • 5831
                  LOL I just noticed the poster has a 3100. So the beretta.net adapter will work I guess???
                  But anyone with a 2.8L/3.1L will need more than just a plate.
                  • Manitcor
                    • 573
                    when I went from a 95 3100 to a 99 3400 I had to have an adapter plate made. Mine is kind of ghetto and I would like to make a better on when I have time.
                    We bought gakets for both types of EGR and used those to make an adapter out of a 1/8" thick steel plate. You will need longer bolts when using the adapter plate.
                    1995 Monte Carlo LS
                    3400 SFI 60v6
                    • geoffinbc
                      • 5831
                      In our case the adapter is about 1" thick it needs to be this long to provide enough lenght for the hose to reach the manifold.
                      • Cliff8928
                        • 532
                        Why? You'll only need the plate, just like the upgrading 3100 owners, because you'll obviously have (or should) switch the exhaust manifolds, so you'll already have all the regular 3x00 parts right there, just like the upgrading 3100 owners have! Unless you actually plan on using old exhaust manifolds and/or the EGR pipe!
                        Cliff Scott
                        89 BerettaGT <-EGR pipe just kinda tucked under and crimped off
                        89 Volvo740 <-no EGR at all
                        Cliff Scott
                        89 BerettaGT
                        04 AleroGX
                        • feavs
                          • 69
                          I have done up a plate for a 3.1 egr for a 2000+ intake manifold as well.
                          Some pics are on my site near the bottom, although they don't show it the best.
                          feavs
                          • geoffinbc
                            • 5831
                            Yes I have seen your site. I even e-mailed you about it. Looks very similar to ours like I said in the e-mail. But didn't you use muffler cement to make the hose fit the manifold?
                            • feavs
                              • 69
                              I used shims and muffler cement to make the hose fit into the egr. It still uses the stock threaded nut thing to connect to the exhaust manifold. I think when I put that car back on the road (messed up power steering line, and got major problems taking it out, causing it to be off the road for a while) I may braze the hose on. Atleast, thats the plan so far, unless something better comes to mind. The shims/muffler cement worked as far as I can tell. I had a bit of an exhaust leak at high rpms, but it's likely that was coming from my homemade downpipe flange, and not the egr, as I first suspected. And that leak only happened sometimes.
                              Was it your pics of the adapter that were on v6z24.com recently? If so, your right, they look very similar, although your's is much prettier.
                              feavs
