Has anyone else used the newer style injectors with Gen II fuel rails? I am running GM #25323971 injectors in the race engine that I am finishing assembly of. A buddy of mine helped splice the proper injector wiring clips onto my Gen II wiring harness so at least the wiring should be "plug and play." I have a question about the fit of the injectors in the fuel rails though. The original injectors each had a metal clip that held them snuggly to the rail. Due to the shape of the new injectors, these clips won't fit them. Is there a different style of clip used for the newer injectors? If so, does anyone have a part number, or even better yet, six clips that they would be willing to sell me? Help will be much appreciated as always!
Fuel Injector Upgrade Question
Joe Morgan
bracketracer
'93 Sunbird SE 3.1/5-speed 14.869 @ 90.96 Heavily Modded
'00 Grand Prix GTP Sedan 13.689 @ 100.97 Lightly Modded
'09 G8 GXP Manual Trans 13.166 @ 106.47 BONE STOCKTags: None
If noone has these, I would appreciate knowing what year and model these injectors are from. I believe them to be 3100 around 2000. That way I can contact the dealer to order them. Thank you!Joe Morgan
bracketracer
they are the 2000+ 3x00 and should flow 22lbs hr at 55 psi
there should be numbers on them like 0 280 and different numbers after that take those numbers and go here to find out what they flow
from this site http://www.fuelinjectorwhse.com/injectors.php?id=MP3067
they come with a 2 yr or 24,000 mile warrentysigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Thank you for the info! They do show my exact injector on the site. They list them as 11.8 ohms, 200cc@3 bar. I assume that translates to the 22 lbs/hr @ 55 psi that you mentioned.
Still seeking info about the injector retaining clips though. Do the 3X00 engines use them? I will check with the dealer just to be sure too, and order them if they do.Joe Morgan
bracketracer
yeah that places tests them at 43.5 psi
yeah the 3x00's use a little clip kinda like a C shape but has two arm's that grab on to the railsigpic
99 Grand Am GT
bracketracer
99 Grand Am GT
Thanks for the picture. These clips are very different from the earlier style that I have, so I will be ordering them from the dealer today. I really appreciate all the help!Joe Morgan
bracketracer
i dont know if you have any junkyards around you but you could prob go there and get enough clips and have spares for the cost of what they charge you to get in the yard.
i dont know what the dealer charges for them but thats another option.sigpic
99 Grand Am GT
Dealer cost isn't really that bad, only $10.06 for the set of 6. I couldn't save enough to justify the trip to the salvage yard, or the time it would take to pull them.
Thank you for all the excellent info!Joe Morgan
bracketracer
thats pretty resaonable. for that money i couldnt justify the trip myself eithersigpic
99 Grand Am GT
I just got back from the dealer with the clips. They are slightly different from the ones in your picture, but they work perfectly. The parts guy said they are correct for 2001-2005. You actually get a packet of 8 of them (they must be the same for some V-8 application too), for $10.06 + tax. They are GM part #17113670 in case anyone else needs to buy them too. Thanks again for all the help!Joe Morgan
bracketracer
