3500 lifter questions
  • merlot566jka
    • Nov 2006
    • 570
    is the plunger suposed to move around when you shake the lifter?
    is it supposed to be fairly hard to move the piston inside (lifter not pumped up and dry-no oil)?
    are my lifters screwed?
    can i use 3400 lifters (the dealer couldnt help here)
    2012 Chevy Sonic Turbo 6spd
    Live life 3.7mi at a time
    • 4555
    They shouldn't rattle, and AFAIK the 3400 lifters are identical.
    • merlot566jka
      • Nov 2006
      • 570
      anyone else....are they screwed?
        the spring isn't that hard to push down but the piston shouldn't rattle around at all, it's a very tight fit.
        3400 lifters are identical to 3500 lifters. I've had both apart this weekend.
        • merlot566jka
          • Nov 2006
          • 570
          damn, new lifters it is. thanks folks
