3500 swap done!!
  • issues
    • Jul 2007
    • 29
    3500 swap done!!
    Hi all Well i got a 95 corsica that had a 3100 in and now has a 3500 picked it for $600 with 28k miles. I ran in to some problems like the tranny bell housing broke i got three bolts and one dowel pin holding it in place, that just gives me more of a reason to swap in a 5speed man in there "any recommendation on what car to get the tranny from ?" Man all i got to say damn that car is quick as f@ck i only given it 1/4 to 1/2 throttle, my old 3100 would only dream of lighting the tires up from dead stop or anywhere this 3500 will do it anywhere anytime. Currently i am getting ready to repin my cars wiring harness for a 97 PCM hopefully that goes good and smooth, as soon as the weather lets up.
    Kevin
    95 Corsica - 3500 swap
    PitbullHQ.com
    LOL awesome man
    I take you you've seen the OBDII swap how-to on www.bstuff.com? But if you figure out how to do it without swapping harnesses please post the info!!
    For trans, you'll need to weld in the mount to the body, and any 93-87 5spd will work from a beretta or caviler or corsica. The later year ones have internal slaves. You want the 282 getrag which I think was only offered in the berettas behind the 3.1's.
    Until you swap trans, don't do long one wheel burnouts or you'll blow your trans.
    Crazy how just 40hp more makes your car fast huh?
    • issues
      • Jul 2007
      • 29
      No i have not seen the OBDII swap on that site, i been talking to Ryan at gmtuners on doing my swap. I'll have to check that how to over and see what they got
      Yes it's crazy how 40-50hp can make a big diff, just little over 1/4 throttle im at 100mph.
      One wheel burnouts my car doesn't know what that is, both my wheels spin together left a nice dual mark out on the street.
      PitbullHQ.com
        You should join on that site. Lots of corsicas and berettas on there. Loner666 is on there, he has a turbo corisca with 3400 and 3500 heads and a cam.
        Here is the OBDII how to. It tells you how to do it without swapping interior harness, you just swap the engine one.
        What plenum and throttle body are you using?
        Are you using the stock exhaust? (if so you are choking the motor, the stock downpipe is 1.65" inside diameter!)
        • issues
          • Jul 2007
          • 29
          I'm using the 3500 plenum and a 3400 throttle body.
          Yes it's the stock downpipe for now, I measured mine when the engine was out it was 2" - 2"1/4 id
          PitbullHQ.com
            Uhm, you measured the double walled part of it? It's tiny!!! Way smaller than that...
            • 19Cutlass94
              • Apr 2005
              • 770
              The stock downpipe that was on my car was about 1.25"
              3400/Getrag 284 5spd
              350/NV3500 5spd
              2014 Chevrolet Malibu LS
              • issues
                • Jul 2007
                • 29
                I could me wrong i know the outside is like 3"where the donut gaskets is , i swore it was inside 2" / 2"1/4, like i said i could me wrong. As of now it's been sitting for the past week i only put about 90 miles on it, till i get everything fix and done.
                PitbullHQ.com
                  Yeah, the flange is big, then you look down in there and it snakes down. It's pathetic! The older 2.0's had a bigger downpipe on the inside!!! Where are 3100_MPFI's pics he has some that show the downpipe..
                  • issues
                    • Jul 2007
                    • 29
                    I plan on addressing alot of stuff after the tranny gets takin car of first, downpipe being one cause i always get leaks there i'll install a section flex pipe to help with that. But for now it repining and install my OBDII PCM
                    PitbullHQ.com
                    • 3100 MPFI
                      • 1522
                      This is the stock 3100 downpipe in a W-body, which is the larger car. As big as my car is, and as small as yours is, I can't imagin yours being bigger. This one is 1 7/8 ID.
                      By the way, sounds like you got something pretty special. I can't wait to see pics, and welcome to the board.
                      Taylor
                      1998 Lincoln Mark VIII
                      • issues
                        • Jul 2007
                        • 29
                        Well looks like i was wrong, yea i need to snap some pics. I'm just taking it one step at a time and taking my time so i don't screw anything else up. I'm not in a big hurry to get it done the way gas is going and 70mile round trip to and from work I'll just drive my other car that gets 40mpg for now.
                        PitbullHQ.com
                          Congrats and welcome to the 3500 swap club..
                          • Barry
                            95 Beretta LG8 Action
                            • Aug 2007
                            • 269
                            You may have the first 3500 corsica? Can anyone confirm this? Nice Work man!
                            95 Beretta- Lg8 Daily Driver
                            • issues
                              • Jul 2007
                              • 29
                              That would be pretty sweet to be the first for a corsica. Thanks
                              PitbullHQ.com
