which cam
  • 923.4v6
    • Feb 2008
    • 182
    • ezrollin
      • Dec 2003
      • 205
      GMcratemotors.com has the 3.4 cam for $116 but don't see the springs or retainers listed.
      • 1986
        • Mar 2008
        • 41
        Originally posted by 923.4v6 View Post
        Crane makes those cams for gm but personaly I don't like Crane I'm a Comp man
        whats wrong with crane? is it just your personal prefrence or you've had bad experinces?
        s10s ive owned
        87-2dr 2wd blazer 6/7 drop-sold and missed
        82-s10 pickup long bed-sold thank god
        86-2dr 2wd blazer 6in. lift 31" tires-sold
        92-s10 pickup ext cab3.4L-6/7 drop
        • 923.4v6
          • Feb 2008
          • 182
          Just my personal prefrence I've owned a 60* cam and a v-8 and didn't like neither one. Owned a comp x-trem energy for a v-8 and loved it
            Comp's 260 cam is a single pattern, you'd usually only run a single pattern is your exhaust ports flow more than 80% of the intake ports.. which isn't the case on iron heads.
            I had a Comp roller cam in my T/A and i was never impressed, the fuel pump lobe wiped off while using a stock pump and it deffenetly never performed like they promised. 240 WHP/320 TQ with their $1100 retro fit roller setup, headers, single plane intake, 750 carb and some light headwork.
            • 923.4v6
              • Feb 2008
              • 182
              #21
              [QUOTE=Superdave;358606]Comp's 260 cam is a single pattern, you'd usually only run a single pattern is your exhaust ports flow more than 80% of the intake ports.
              so would you want to buy a cam to keep the cfm's at 80% flow (if you know the flow numbers of your heads)?
              • 92_lumina
                • Apr 2008
                • 55
                #22
                Originally posted by merlot566jka View Post
                crane 272. good power, great economy and sounds like a lumpy cam. easy fo tuning
                how are going about the 4.3 setup? just using the 4.3 tb with injector? most of the 90 degree v6 parts are not interchangable. are you fabricating?
                I thought the 3.4 camaro's were roller engines?
                  • 9189
                  #23
                  Nope, the only roller engines are the 93+ aluminum head engines (3100, 3400, etc).
                  • toy60
                    • 3
                    #24
                    I'm basicly doing the same thing to my 3.4 with a 700r4 in a Toyota 4x4 and I talked to Mark Engle of Engle Cams yesterday about their cam 21640-H that has 215 @ .050 and.453 in and .471 ex with 112. He said there would be no lope in the 60 degree motor. I have always thought that when you get past 210 degrees @ .050 on the intake side that you can expect to get some lope.SoI'm not sure what cam I going to use.
                    • 1986
                      • Mar 2008
                      • 41
                      #25
                      anyone ever used isky?
                      s10s ive owned
                      • latemodelnewbee
                        • Jun 2007
                        • 227
                        #26
                        I have used an edelbrock torker (or torker 2) cam in a carb. 2.8L. It sounded mean, like 3 harleys idling. It was in an 84 cherokee chief with the edlbrock 4 barrel intake and 600cfm carb, with 3.55 gears and a T5 tranny it would smoke all four 31" mudterrains. But I don't how it would work with the fuel injection
                        68 El camino 454 speed muncie 3.90 posi 12 bolt,
                        80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
                        60 Impala 2 door hardtop L79-327 T56 4.11 posi.
                        83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
                        91 Z34 now has a hm284. and belly pan in the works
                          Yep.. or better.
                          If you look at the specs for the Crane H260-2 VS the Comp 260 you'll see it..
                          Comp 260
                          Advertised duration 260in/260ex
                          Lift w/1.5 rocker .440in/.440ex
                          Crane 260
                          Advertised duration 260in/272ex
                          lift w/1.5 rocker .427in/.454ex
                          you can tell that Crane actually looked at the flow numbers of the heads (probably the iron heads) and figured out what would be best.
                          the Comp 260 would work ok if you were using the aluminium gen3 heads because port flow is so much better on those.. still not much of a cam by todays standards.
                          • powerdoctor
                            • Apr 2008
                            • 133
                            #28
                            Before I would recomend something, I would want to know what you are using this truck for?
                            Is it a 4x4?, 2 wheel drive?
                            If you are playing in the mud, you would want a wide lobe sep cam for increased low end power.
                            If you are racing it, then tighten it to 108/105 lobe sep.
                            If you are wanting this to be a "daily driver" just put the 3.4 lower in and be happy.
                            If you put the bigger tb on it you will need to add headers at least.
                            Really your power will come from compression.
                            The 3.4 with the 2.8 heads will more than accomplish this "bump" in compression due to bore and stroke differences.
                            Do not mill the heads unless you need to, you will need to "mill" the intake to match the heads at this point if you do.
                            Timing will be your other issue, but you have a distributor so this will be realitvly easy.
                            About 20.0/ 23.5 degrees at IDLE will be a good "curve" for the tb s-10.
                            Roller rockers, roller chain, ect... for freeing up H.P.
                            As A final note, DO NOT grind off the "bumps" in the intake ports of the heads.
                            These are not emission devices, they are actually venturi that help "bend" the intake charge into the cylinder and equate to a 17% increase in airflow over removing them.
                            Also do not "polish" the intake side of the heads, this will mess with atomization, and cause "pooling" of the fuel in the runners.
                            If you need to know more e-mail me.
                            !!!!! BOSCH PLUGS RULE !!!!!
                            http://www.cardomain.com/id/powerdoctor
                            • 923.4v6
                              • Feb 2008
                              • 182
                              #29
                              The 3.4,3.1, and 2.8 all have the same heads so no compresssion change will happen. The carburator heads has smaller valves.
                              • 923.4v6
                                • Feb 2008
                                • 182
                                #30
                                Yep.. or better.
                                Comp 260
                                Crane 260
                                do you know what the perfert % flow would be between the intake and exhaust
