3500's o2 sensors
  • merlot566jka
    • Nov 2006
    • 570
    3500's o2 sensors
    can they be used with obd1? i thought i read that that they had been changed or wouldnt work for some reason?
    i could look up the numbers on the few that i have from 3500's but i wont beable to get my hands on my sensors till weds, and thats when i need to fire up the car.
    can anyone advise?
    2012 Chevy Sonic Turbo 6spd
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    They are said to be non interchangeable with the older style heated o2's.
      Yeah SuperDave was getting some weird readings with his and went back to 3400 one and was good after that.
        I'll test that again this year, i was having alot of other issues with the car at the same time.
        Basically it would bounce in and out of closed loop constantly, it did it for a little while with the 3400 o2 as well then fixed itself.
        the plug is slightly different for the 3500's o2, you gotta cut a notch in the older 4 prong plug so that it'll fit in.
          hmmmmmm!
          • merlot566jka
            • Nov 2006
            • 570
            okay, well ill try the older style....
            anyone have wiring diagrams for one? i need to get one on my fiero so i can datalog faster
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              I have a sensor with pigtail if you're interested. http://60degreev6.com/forum/showthread.php?t=39720
              • Joseph Upson
                The later model O2 sensor works fine for me. It will not if you don't have it connected properly. I tried with and without the heating element connected and it worked under both circumstances going into closed loop very quickly when powered up. Superdave has such a big cam that maybe the rich fueling condition he had early on cooled the sensor too much or maybe there was a bad connection because once my datalog showed closed loop it stayed that way with exhaust gasses from only 3 cylinders.
                • merlot566jka
                  • Nov 2006
                  • 570
                  no thank you sir, lol, i work at an exhaust shop and have o2 sensors out the wazooo
