GEN-III Double Roller TC update
  • CNCguy
    Bisong eater :P
    • 1017
    For those who haven't been following this project, the sprockets are made from billet 4140, use a standard Cloyes chain and will allow cam timing to be set at 0, +3, +6, -3 & -6.
    Here's a pic of the progress to date.
    (edit) Fixtures are finished and engraving is complete. Still need to cut keyways. Getting closer.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
  • johnnymossville
    • Jul 2007
    • 255
    How much will they cost and when will they be available? I have been hoping that this would get done before I assembled my engine. Will I "get lucky"?
      lookin good!
      • zofo61
        Banned
        • Oct 2005
        • 436
        Put me down for a set for sure......looks great. Will the front cover need to be modified? and will that be available as well?
        • Alxsmt
          that one guy
          • Feb 2007
          • 725
          im buyin a set
          • merlot566jka
            • Nov 2006
            • 570
            are those navy digi camies in the background?
            nice work tho! i would have loved a set a month ago!
            2012 Chevy Sonic Turbo 6spd
            • torq455
              If I only had money!!!
              • 1615
              Andy
              fastest 1/8: 10.19@ 67.17
              fastest 1/4: 16.16@ 82.70
              • MY91GT(Z)
                • Sep 2006
                • 387
                pendin on when these will be done i would like to put 1 in
                • CNCguy
                  Bisong eater :P
                  • 1017
                  Thanks guys.
                  I won't have a final price until all the bills come in for the outside services (gear hobbing, heat treating and keyway cutting).
                  They are at heat treat now and barring any unforeseen problems, they should be ready in a couple of weeks.
                  These were designed to fit under a FWD cover with minimal grinding. With each TC set, I will be supplying a small step gage to check for proper clearance. The oil galley plugs (behind the upper sprocket) need to be shortened and possibly the areas around the plugs. The inside of the cover may require a small amount of cutting with a disc grinder.
                  The camo material was left over from my sons project. He picked up a trashed 600RR, did some rough patching of the fairing and tank, then covered the bike with the camo cloth. I guess it's a ratbike, different but looks pretty good really. The camo does a decent job of covering the rough body work. Guess that's why it's called camouflage.
                  '79 MGB - LZ9 - T5
                  • sprucegagt
                    Old School KI
                    • May 2005
                    • 703
                    I take it there is already a set reserved with my name on it?
                    Your local OBDII moderator
                    2000 Grand Am GT w/ WOT parts
                    • powerdoctor
                      • Apr 2008
                      • 133
                      Nice work!
                      You are right about the cam and the plate.
                      I should of meantioned you need to leave a little clearance, like a hardened washer on the cam sproket so they don't get sandwiched together.
                      I though I did meantion that in one post though.
                      You are doing it right though for sure.
                      If I had the time and machine shop thats how I would of done it.
                      Even with the keys cut and the heat treating, the sproket should not be too much.
                      I will deffinately want one as well.
                      Where are you going to sell them, the store here? or do we get them right from you?
                      !!!!! BOSCH PLUGS RULE !!!!!
                      http://www.cardomain.com/id/powerdoctor
                      • CNCguy
                        Bisong eater :P
                        • 1017
                        These will be available through the store as we don't sell direct.
                        I edited the first post about the progress and added another picture.
                        '79 MGB - LZ9 - T5
                        • loner666
                          • Oct 2006
                          • 435
                          Hmm. When/If I redo my engine I may just look into getting one of these. Nice work as always
                          Best 1/4mile ET - 12.9
                          Best 1/4mile MPH - 111
                          1997 Ford Ranger Splash
                          Daily Driver
                          • G-U-NOT
                            Banned
                            • Jan 2006
                            • 158
                            Keep us updated.... I want a set!!
                              Live life 3.7mi at a time
                              • 4555
                              I see that you are going to cut multiple key way's in the crank gear?
                              Very clever I was thinking you would be drilling multiple holes for the pin.
                              EDIT: What's your plan for tolerance compared to the different generations? The Gen1 is almost a press fit gear on the crank key, where as the Gen3 is a loose fit. I would think it needs to match the Gen3 because the crank gear is what takes up the lateral movement. The Gen1 allows the cam to take the slack and the crank gear is stationary.
                              Do you think the multiple key ways are going to cause issue with the gear strength or stability to hold true timing?
                              Nevermind, 4140...
                              PS: What are you using to stain your engravings? Dykem seems to work good.
