can fouled plugs cause a no start condition?
  • merlot566jka
    • Nov 2006
    • 570
    well i tried all day to get it started today, no luck.
    ive got fuel pressure, pump is priming, injectors are injecting...
    i used a timing light on the wires to see if it was firing...some were some werent... i tried a new icm and coils...no change.
    took the crank sensor and waved my pocket knife in front, i can hear the injectors firing and a few of the lugs will light up, but not all
    i took the plugs outa the rear bank and cleaned them with a wire whhel and brake clean, it got a few chugs and thats it. they are deffinatly fouled. so i bought new plugs right after i got off work and i wont beable to put them in till the morn.
    my question is would fouled plugs cause me not to see the spark on some wires (using a timing light)? could they cause a no start?
    i have power at the coil, all grounds check out, all power checks out, injector drivers are pulsing, and im just stuck.
    it was really raining good yesterday and i fear that had something to do with it.
    if its not one thing its the next. i love this car
    2012 Chevy Sonic Turbo 6spd
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Absolutely. If there is fuel on the plugs they will not spark.
      i had this exact thing happen today.. car would randomly pop out the exhaust while cranking.. all 6 plugs were fowled to hell.
      • merlot566jka
        • Nov 2006
        • 570
        i got one good backfire...sounded like a shot gun going off. everybody came running out of the shop to make sure i was alive. the police even showed up. lol. bout the only fire i had today tho
        k new plugs it is....
        • merlot566jka
          • Nov 2006
          • 570
          know of any plugs that are a heat range warmer? all the local guys at the part stores are idiots and cant help me.
            just pull all yours out and sandblast them clean.
            i did that earlier and they work like new again
            • merlot566jka
              • Nov 2006
              • 570
              dont have a sandblaster. just got some new ngk tr55 for $9
              car fired up on the first crank
