spark plugs
  • Alxsmt
    that one guy
    • Feb 2007
    • 725
    spark plugs
    can i only get ac delco platinums for my 3400?? do i want platinums? i was gonnna go out and buy a bunch of plugs to index them but im not gonna bother at 7 bucks a piece!
    You can use any AC Delco 3100/3400 plug ever offered. I run the old plain ones in mine. You can do plain, plat, or iridiums.
    See here:
    http://60degreev6.com/forum/showthre...559#post328559
    I run the cheapie plain R44LTSM6
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      oh nice! so with one you wont get any more "power" than another? just wear?
      • 19Cutlass94
        • Apr 2005
        • 770
        You wont really get any more power with any different plug, its more about change interval.
        3400/Getrag 284 5spd
        350/NV3500 5spd
        2014 Chevrolet Malibu LS
        • 3100 MPFI
          • 1522
          For me, I stick with either the cheap delco's or if I am feeling frivolous, then I will get RAPIDFIRES. Platinums don't seem to last long for me.
          Taylor
          1998 Lincoln Mark VIII
          • Alxsmt
            that one guy
            • Feb 2007
            • 725
            ok thx guys
            arnt rapid fires like 20 a piece? and ive heard ur not sposed to gap them, is that correct?
              I'd go plain, or the latest GM iridiums as they have been used for a long stretch and not changed by a new part number, so GM must be pretty happy with them.
              On platinum and iridium coated tip ones, you can gap them, but you can't do it by prying on them as it will scratch the coating off. You have to grab and pull it apart to make the gap bigger instead of putting something between the two and prying.
              • 3100 MPFI
                • 1522
                RAPIDFIRES are normally $4.99 each. I have always gapped them. I don't trust the PRE-GAPPED spark plugs. Those things get thrown around while being shipped, and I have yet to get a full set that were all gapped the same.
                Lets put it this way. I just put 6 new plugs in my 3.4 DOHC. Of the 6, five of them I had to adjust, and 1 was fine.
                Taylor
                • Alxsmt
                  that one guy
                  • Feb 2007
                  • 725
                  ok, im with ya on that, i have never had any plugs gaped correctly outa the box.
                  4.99 doesnt seem too bad, are these dealer only plugs? and what is soo good about them?
                  • 3100 MPFI
                    • 1522
                    you know, I never really looked into what makes the rapidfires so special. I know they would last longer than any other plug in my 3100 MPFI (high compression engine).
                    No, they are not dealer only. I get them at O'Reilly auto parts.
                    Taylor
                    • merlot566jka
                      • Nov 2006
                      • 570
                      i use ngk tr55's. mainly cause i foul out the plugs every few weeks and these are $13 a set
                      2012 Chevy Sonic Turbo 6spd
                      • bkaab
                        • Mar 2008
                        • 68
                        I am just running the cheap AC Delco's under 2 bucks a piece.
                        2001 Grand Prix Topswap GT-(12.71@107.92mph)
                        1996 Grand Prix SE-(17.32@80.23mph) Turbo Project
                        1990 Turbo Grand Prix-project restore
                        • Ortie666
                          • Jul 2005
                          • 340
                          lol, funny thing is those are the olny ones that can hang with nitrous without melting electrodes
                          Six-t-Six Motorsports
                          2.8L Chevette Roadcar
                          3.2L Acadian Racecar
                          • Rhedalert
                            Dr. Feelgood
                            • 1574
                            Does Schmucks have them too>>
                            Brian
                            3400 SFI V6, 4T60e
                            • Alxsmt
                              that one guy
                              • Feb 2007
                              • 725
                              ACDelco RAPIDFIREŽ Performance Platinum Spark Plug
                              ACDelco's RAPIDFIRE Performance Platinum Spark Plugs offer longer life and improved efficiency over time as compared to conventional spark plugs.
                              Available for most vehicle makes and models, and several marine applications, the RAPIDFIRE Platinum Spark Plug design features:
                              Ribless insulator that may improve the plug-to-boot seal
                              Tapered center wire electrode with a platinum pad that reduces the firing diameter and helps improve the firing efficiency by concentrating and directing energy needed to fire the plug with less voltage
                              One-piece integral suppressor seal that helps reduce radio frequency interference, meters spark plug energy to help provide long electrode life, and seals against compression leakage
                              When compared to conventional spark plugs:
                              Reduced sparking voltage
                              Greater corrosion protection
                              Fits engines that run conventional plugs, as well as newer vehicles that require platinum plugs
                              Includes several marine applications
                              Three-year limited warranty*
                              that was from AC delco's website. napa has them for 50 cents more than stardard plugs. i think i may just get them. if i do i will post the part number for reference
