3400 pistons and connecting rods
  • 92cavquest
    • Feb 2008
    • 150
    I have been looking at a couple of pistons on summitracing.com. Using their search feature I came up with two piston options for the 3400.
    Their part #'s are STL-H847CP50MM and STL-H847CP. Will either of these work and what would be CR be on a stock head?
    Also, I'm having no luck with connecting rods. I've read on here that SBC connecting rods will work with a little modification, but can anyone point me in the right direction?
    • 9190
    Those are the same, except one is an overbore piston (.5mm or 0.020").
    As far as connecting rods : http://60degreev6.com/content/Connecting_Rods_0
    • 92cavquest
      • Feb 2008
      • 150
      Good read on the connecting rods. Thanks a bunch.
      Does anyone have any experience with these pistons? Anyone recommend them or know what the CR might be?
        • 9190
        Pretty sure they are just stock replacements. If Summit has data on them (compression height, dish volume, etc), you can always plug it into the site's CR calculator (http://60degreev6.com/CR_Calculator) to determine what CR you will end up with.
