im putting togeather a 2.8 build, im going to use the camaro sfi intake, can i use aluminium heads with that intake, they will need to flow pretty good cause its gonna be t/c'd
aluminium head question
Tags: None
Nope, ports don't line up between the aluminum heads and iron-head manifolds.-Brad-
Go with 3400 heads and 3400 intakes. You'll thank us later
You'll need to convert to DIS and MPFI though.
heads and intake from a front wheel drive? i have the camaro sfi manifold, and if i put this motor in anything its going to be an s 10
Yes, heads and intake from a FWD. All you have to do is rotate the intake 180 degrees and you are all set.-Brad-
so i take the top end off a fwd car, and just switch the intake 180 like that? why wont the camaro intake fit on aluminium heads?, i would perfer that one to work
the FWD stuff far out-flows the RWD stuff, night and day difference.
True that, and a smaller better shaped combustion chamberOriginally posted by Superdave View Postthe FWD stuff far out-flows the RWD stuff, night and day difference.VIDEO Acadian http://videos.streetfire.net/video/8...7f00197eea.htm
Six-t-Six Motorsports
2.8L Chevette Roadcar
3.2L Acadian Racecar
Compression is going to be high unless pistons are also changed.
