300 crank hp on the 3.4l(boost)?
  • citr0
    • Jul 2008
    • 9
    Many people have turbo'd stock 3400's and they have around 9.6:1
    Okey. hmm but how much boost do they charge ?
    Originally posted by Superdave
    400+ HP on iron heads.. alot of boost though.
    thanks, that was a good link.
    How much boost do the stock piston in a 3.4l handle ? as i understand the rod are forgings ?
    if i do what i wrote and get 200 hp (230 crank hp ) at the wheel. How much bost does it take to get in the 300 zone ?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      With a great tune the pistons should last for a long time. It's the higher rpm's that like to wipe out a cam lobe.
      • Guest
        I have about 10 psi on my 3.4 with mild port heads and a 272 crane cam. Its making about 240 whp through a getrag 5 spd in a fiero. Its close to 300 crank but it would probably need another 2-3 psi of boost to make it official.
        I am using hypereuctectic pistons. Nothing special, and I have been known to spray a decent amount of nitrous on top of it with no problems either. its not a built motor by anymeans but on the nitrous its probably close to 400 crank hp and its holding up fine. Its all in the tune.
        I have a build thread on www.realfierotech.com.
        • hookdonspeed
          • Jun 2007
          • 322
          cit, u can do like im thinking, 3.4 with the 3500 top end, but before i do that, ima boost my stock 2.8 till it goes BOOM.
          im also debating on a 5.3l swap.... 303hp out of the box.
          • ssdurango
            • Dec 2004
            • 170
            I just dyno'd my 3.4 (iron head) and I got 231.4 hp at the wheels! It's a supercharged/ 100% propane engine, running about 11psi. Thats about 295 hp at the crank so it's not too hard to achieve 300.
              #21
              If his dyno #'s were true, MidnightRiderZ24 did 358hp to the wheels on a 3400 with 9psi.
              • MidnightriderZ24
                • Jan 2005
                • 699
                #22
                my boost gauge said 10, the dyno said 9psi. i trust a 30,00 dollar dyno over a $60 gauge.
                mind you this wasnt a crazy tune. i did lots more upgrades tuning after this dyno. as long as you know what your doing it isnt hard to make power out of a stock engine.
                [SIGPIC]
                12.268@117... 11's to come!
                • ssdurango
                  • Dec 2004
                  • 170
                  #23
                  What does stp corrected mean?
                    they must have been manually correcting for the current weather conditions.. usually SAE corrects automatically.
                    • Joseph Upson
                      #25
                      I think that's the name of their Dyno program since it is used several times combined with other terms. Otherwise I would take it to mean; standard temperature and pressure.
                      • citr0
                        • Jul 2008
                        • 9
                        #26
                        yeah thats nice...do you got a build up thread ?
                        give me som tips man
                        • ssdurango
                          • Dec 2004
                          • 170
                          #27
                          You don't want tips from me... I cracked a piston!
                          • hookdonspeed
                            • Jun 2007
                            • 322
                            #28
                            well, shoulda been using that race'n gas not that cook'n gas.
                            • ssdurango
                              • Dec 2004
                              • 170
                              #29
                              Hahahaha like I haven't heard that one before! Propane has higher octane then most racing gas anyway. My timing under full load was way off I think.
                              • citr0
                                • Jul 2008
                                • 9
                                #30
                                okey, i finaly got the engine. it takes it time from USA to Norway
                                i been reading about a 3.4 hybrid motor. 3.4 iron block with 3400 heads ?
                                but im confused.
                                in short therms what must be done ( wires, DIS ? )
