Offset crank grind topic again
  • Joseph Upson
    • Oct 2026
    I made some positive progress regarding my intent to do this. Flatlander racing was a waste of time, an important point to make about the 60 deg crank is individual crank pins versus shared on the other engines which means more labor to resize the pins than what would be necessary for the V8 and 90 degree V6 motors. I was quoted over $600 from flatlander in a not so friendly tone. So I searched some more.
    Mike at Valley Crankshaft.Inc does a lot of offset grinds and was very accomodating and gave me an estimate of about $350 for an offset grind. Up to .11" increase in stroke should be possible if the 2" big end bearing 5.7" rod is used. Combine that with the 3.6L or the correct compression height 305 pistons and that should provide a sizeable increase in displacement in a 3500 block.
    My plan is for forged LS1 pistons and adapted forged 6" sbc rods in my extra 3900 for a forged build up with a .075" offset for the 2.1" big end rod to maintain strength above the earlier cast 2" pin crank. The 3.9 and LS1 share the same bore diameter making forged pistons available in sets of 8 at roughly half the price of a custom set of 6 and there are numerous LS1 pistons and rod combos that will go together to achieve this process.
    For those interested in a naturally aspirated setup there are LS1 pistons available within .001" compression height of the stock 3900 pistons that will push your compression ratio high enough to build a ground pounder like Superdave's only better.
    While looking over old pics I happened across the bottom end of my old 2000 3100 V6 and noticed that the oil pan rail of the block does not have the connecting rod relief notches present in the 3500 and up V6 motors. When I return home I intend to do a mock up to see just how much room is available for the increased stroke that GM indirectly stated there was room for, for future displacement increases.
    Given the deck area increase of the VVT 3500 and 3900, it can easily be turned into a 4.3L, if they took the 2.8L all the way up to 3.5L in the same package, I see no reason for them not to do the same with an engine series not only APPARENTLY more efficient than the 3.8L & 4.3L, but smaller and packed with even more potential with the VVT option.
    Gas prices are going to force them to do more with little to stay competitive.
  • IsaacHayes
    Mr. Orange.
    • Apr 2006
    • 6030
    Stroked, built, high compression 3900... Sounds nice... Someone do it!
    • gectek
      Banned
      • Aug 2006
      • 1472
      oh you have no idea...a monster in the making is what i say...but also you need a stand alone ECM to make it plug and play, AND to make it able to be run on the dyno...thats what i might be working on...
      • Joseph Upson
        I just received an email from EFILive stating that their tuning software/hardware should handle making the 3900 PCM standalone from the other onboard vehicle interfaces it is normally tied into, for swapping in other vehicles. I noted also that the 3.6L Saturn Aura is on the list. The problem is I believe their equipment is in the $700 range. It would be later this year that I would look into sending the crank off and my setup would be for around 9:1 compression and about 18 psi boost using code 59 and if possible piggy back OE PCM for proper VVT control only as boosted code is not yet available in the later PCM V6 code.
        • gectek
          Banned
          • Aug 2006
          • 1472
          I would really like to see that, because i have both softwares/interfaces
          • Monzsta
            • Jul 2007
            • 132
            Keep in mind balancing will be required, and will likely need to include mallory, but I like your plan. I wish to hell I was still grinding cranks for a living. I'd have already done this.
            '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
            1/8 mile 9.72@75 mph, 2.0 60 foot
            • gectek
              Banned
              • Aug 2006
              • 1472
              balancing is really a no brainer when it comes to making any HP or cracking into the engine...it really isnt that expensive for the gains you can get from it...piece of mind, and a little better power output and maybe not so many bad harmonics....
              I think anytime you change the pistons, rods, or add a flywheel to swap to a manual trans or the other way around, the crank should be balanced...i got mine for $225
              • candychevy87
                anthony
                • Jun 2008
                • 76
                do ittttttttttt
