bin file won't run
  • 923.4v6
    • Feb 2008
    • 182
    bin file won't run
    does anyone see why this bin wont start my car, it acts like it may be to high in time. It will hit then drag. Also did I disable my egr, vats, and speed limiter correctly, it should have 24lb injectors also. thanks
  • torq455
    If I only had money!!!
    • 1615
    comparing to my slightly modded 3.1, all of your VE tables are extremely high, at least 2x as much as mine. timing looks ok to me. your open loop AFR looks rich too. is the 88.xdf a stock file for 3400?
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
      that bin is AFU.. those VE tables are all wacked out and the spark advance table isn't right either...
      Try this one..
      • 923.4v6
        • Feb 2008
        • 182
        they are stock for a 92 5-speed 3.1 camaro
        • 923.4v6
          • Feb 2008
          • 182
          Try this one..
          Thanks, I'll try it tonight after work.
          • 923.4v6
            • Feb 2008
            • 182
            well I just tryed it and its better it would start but would't idle. What would you adjust to adjust the timing at start. If it had a distributor I would advance it some if that says anything. I also believe it may be getting a little more gas when starting since it has a strong gas smell. Would putting the injectors to 25lb help any?
              If you are willing to switch to $A1 code i could help you out a bunch more... either way, datalogs of it running would be nice.
              • 923.4v6
                • Feb 2008
                • 182
                I have the data cable but haven't figured it out yet but I don't think it will idle long enough to datalog. If your talking about the A1.xdf I will try it, it dosen't matter what it is to me as long as it runs. This is my first time trying to tune. I'm ging to disconnect the battery cable tonight to see if that will help.
                • torq455
                  • 1615
                  is the BPC supposed to be that low? i'm at 224
                  Andy
                    with 24lb injectors, yes 150 is about where it should be.
                    I'll look more into that bin today and see if i can find anything weird.
                    • 923.4v6
                      • Feb 2008
                      • 182
                      how long does one have to run to get a datalog? The car will fire up if you hold it on the bottom but will die after it revs up to about 3000 rpm's.
                      It acts like you sprayed starting fluid or gas in the throttle body and it had no gas in the tank, as if the injectors isn't firing. It has 3/4 tank of gas though.
