Where can I tap for oil pressure?
  • evilmiata
    • Nov 2003
    • 156
    Update: I removed the oil-in line at the filter and spun the oil pump with a drill. There's oil and lots of it! Oil also flows out of the filter when I remove the oil-out line. So why can't I get oil pressure?
    Does anyone have a diagram of the oil system?
    How does the valve train recieve oil? Should I see oil feed into the valves if I remove the cover and spin the oil pump?
    • evilmiata
      • Nov 2003
      • 156
      Here's a better question: Do I need an oil bypass valve? Originally there was an oil filter adapter that had the bypass valve in it, but I don't have the adapter. Would this explain my low oil pressure?
      Please help me guys, because I need to drop the whole drivetrain to get the motor out and I'd like to leave that as teh last option.
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Did you check to make sure the cam gear is not sheared off/worn down?
        • evilmiata
          • Nov 2003
          • 156
          I imagine the cam gear is fine. The oil pump drive that replaces the distributor is used but the gears look fine. This is a new GM performance parts engine. However, I did replace all the hardware with ARP stuff so my main concerns are that I somehow improperly installed a bearing or the oil bypass valve is required. Its a big deal to do replace/repair either one (i.e., I'd have to track down an oil filter adapter or remove the whole drivetrain) so I'm trying to avoid any unnecessary work.
