New hybrid,bad idle runs good
  • Russell52
    • Jun 2007
    • 88
    Hey guys,been awile since I started my project,would have never had done it without the forums influence lol..
    Well What I have....
    3100 stock motor
    Bored over 40 thou
    Cam ground by comp cams
    Roller lifters from a 3400
    The required shorter pushrods custom cut,dont even remember from where now,Ohio ?
    Gasket matched ports on heads (3100)
    Uim & Lim from 3400 & T-body
    Everything as far as the motor is new or has been redone,starts up and sounds good and strong,just wont damn idle for nothing.. Tried Idle relearn no go Messed with it for hours tonight and still nothing,Anything above 1k and its real responsive,and sounds good..
    I have Obd 1.5 so that might be a problem,It doesnt know what to do with the cam,or extra air?? When it does try and idle its extremely low and goes from like 400~700/850ish then bounces a little more and eventually dies..
    Russ
    Are you another Candle Power Forums member? LOL Me and SuperDave are.
    Check out the nitecore D10 or EX10... They freaking rock. 4sevens.com if you don't know. It's my new EDC.
    Anywho, I'm guessing you had a 95? Did your heads have notches for the roller rockers?
    What are the specs on the cam regrind?
    Shorter pushrods??? Should be longer if anything.
    • Russell52
      • Jun 2007
      • 88
      I am a cpf member my current EDC Cree based stream light Junior
      The heads were notched already,and the original push rods, were bottoming out he lifter so... ???
      Cam
      Gross valve lift intake .427 exhaust .427
      duration @ .050 intake 210 exhaust 210
      Lobe lift intake .2850 exhaust .2850
      Lobe separation 112.0
      .437" I/e
      196* I/e @ .050
      I;m so ready to drive it,just the damn thing wont idle for me....
        woot flashlight geeks unite!
        EDC'ing a U2 Ultra
        so the cam you put in is smaller than the stock cam? Comp did grind you a roller cam right, not a flat tappet? was it a re-grind or one of their models like the H260?
        Need more info.....
        • Russell52
          • Jun 2007
          • 88
          I believe it was something like a h260,seems as if there was a sticker on the box saying something about that,And I told him that I would have roller rockers,that I had changed over.. Dunno...
            I guess i'm still confused... Comp cams does not make a roller cam for our engines, did you buy a flat tappet cam kit and install the flat tappet lifters as well? or are you running the roller lifters on the flat tappet cam?
            P/N from the cam box would help out alot...
            • Russell52
              • Jun 2007
              • 88
              Roller lifters,the ones with the little roller on the bottom? Ya my engine had those in it,I remember there being an issue of such at Lunati.. Cause I bought new lifters from Lunati and the were flat on the bottom,got home,discovered that I had rollers ..
              Now the old rocker arms didn't have rollers but the new ones from the 3400 do..The cam box is over at my dads,I will go check it out tomorrow,I cant remember what I did with the original paper work from the cam atm,just moved and haven't seen em since..
              Russ
                He cant put a flat tappet cam in a roller block since our cams have one large bolt in the middle to hold the cam gear on.
                Stock cam is .050 Duration 197/197 112 LSA Lobe Lift .273/.273 Valve Lift .436/.436
                So yeah its smaller than stock... Not sure what they started with for the grind, if it was a blank then that may explain the shorter push rod length...
                a OBD1.5 shouldn't have trouble learning that cam since it is smaller... and only 210 duration.... I ran a Milzy stage 1 on a OBDII but it would idle and run with stock tables, so it wasn't necessary to tune to get it to idle.
                • Russell52
                  • Jun 2007
                  • 88
                  Ok let me type what is printed on the box
                  99-999-3
                  Misc 266HR /266HR-M HR112.0
                  Cam Specs---- INT EXH
                  ADV DUR: 266 266
                  DUR @ .050 210 210 LOBE SEP:112.0
                  VALVE LIFT: .427 .427
                  Guess this cam is a waste?
                  If the cam needs to be changed,can that be done without pulling the engine?
                  and where would I get a proper cam,that will be almost aggressive,and still pass emissions test?
                  Russ
                    99-999-3 is a "misc regrind"
                    did you send in your stock cam for a regrind?
                    No, you can't change the cam with the engine inside the car, people have done it in the past but in the end it's just faster to pull the engine back out.
                    Yes, that cam is a waste.. it has a little more duration than the stock cam but less lift so it's not going to perform any better than stock.
                    I'd suggest pulling the engine back out and going all through it again. Post up exactly what parts you have (year and other info) and what you are looking to accomplish with the engine, then we can recommend a propper camshaft and the right associated components to make it perform like you want.
                    • Russell52
                      • Jun 2007
                      • 88
                      There she is a little dirty.. Still had the idle problem,So here is what I did,and I need yalls input on the solution I used..
                      Set the throttle stop in a little,then adjusted the TPS to where it read 0%,and it idles fine,works good into drive etc.. The problem is that I can only achieve 97% WOT now.. I havent driven it much yet cause its not legal yet,But it seems a little under powered.. Is there a difference in 3100 and 3400 TPS's??
                      Let me know thanks
                        So you are holding the plate open more to get it to idle, yet adjusted the tps so it reads 0% at this point? And the TPS will only read 97% at WOT because of that. It shouldn't be a big deal because like 70% or something it goes into power enrichment mode and I think from that point to 100% it's all the same to the ECM. The plate will still be open at 100% though so no worries on that.
                        Less power is probably due to less lift than the stock cam has. Or the ECM needs time to re-learn the fuel trims, even stock engines will need some time and improve with driving around a while normally.
                        • Russell52
                          • Jun 2007
                          • 88
                          heres a quick run in the pontiac,Will post a link to my sorry idle soon,It idles bad when cold but good after its warmed up..
                          Bad idle
                          • Russell52
                            • Jun 2007
                            • 88
                            Ok new problem,unplugged the oxy sensor,and the IAT, started it several times,and drove around on surface streets,then a short run on the interstate,and the computer never threw a code,and there are no codes stored or pending... Bad ecm??
